Ringing/Rattling Type Noise Right front area of car/over slight bumps
Hi guys, I have a slight ringing/rattling type noise when going over slight bumps from the right front of my car (1990 CRX si with b16a1 swap). Any ideas on what this could be? I replaced the both upper control arms and lower ball joints, I'm thinking possible stabilzer link bushings, and sway bar link. Your feedback is appreciated. Thanks and Happy Thanksgiving Everyone!
Sanj
Sanj
If the bolts on the upper control arm that hold the arms to the anchor bolts aren't tight enough you will get some "creaking" sounds coming from the front.
I would go over ALL your bolts again just to make sure they are tightened down.
do you know if you keep the hub ring (press fit into the back of knuckle around the axle joint) in there when you did the swap? or do you specifcally have to take it out?
i dunno about b16 axles, but i had a loose hub ring and it made a real annoying tinny, rattling, scratching noise with stock axles.
alscrx
29
Aug 10, 2021 11:23 PM
SiRkid
12
Jun 9, 2005 12:05 PM
