Need Help Starting my car....JUst messes up..plz help quik..
Old Oct 9, 2005 | 12:13 AM
ivanson's Avatar
Default Need Help Starting my car....JUst messes up..plz help quik..
i got an 88hf with a sohc zc motor...running a pg7 ecu 88hf starter
and flywheel...
when i finished swapping my car it would start on the first click...
like a week later it sometimes it wouldnt start it would just click but
after a couple of clicks it would start.... Then now im at the point where
it doesnt start....So i thought it was the starter
i went and tested it at autozone and it pass...starter was good...
so then i went and tested the battery...it was really messed up so
i bought a new one ...I got the optima gel battery....
The car started with the new battery.....but like the next day it would
do that click sound and wouldnt start after a couple of clicks....now again
im at the point where it wont start...
the lights and the stereo work with the ignition on and everything
powers up but the car just wont start...
i clean the starter and ecu cable and still nothing..
So now im thinking it could be the cables or the main reley..
any help is welcome
thanks ppl hope this explain most of my problem
Old Oct 9, 2005 | 12:15 AM
ivanson's Avatar
Default Re: Need Help Starting my car....JUst messes up..plz help quik.. (ivanson)
and one more thing...
my car does start
when we push start it...
Old Oct 9, 2005 | 01:50 AM
89crx1184's Avatar
did u check ur alternator
Old Oct 9, 2005 | 09:31 AM
ivanson's Avatar
Default Re: (89crx1184)
but shouldnt it still turn on with the battery?
i still got the car to turn on by push starting it...
ill push start it and ill disconnect the battery and
see if its bad..
Old Oct 9, 2005 | 10:16 AM
d16vtecx's Avatar
Default Re: (ivanson)
try changing the alternator
the same thing happened to my homey and it was his alt
autozone will test your alternator for free
Old Oct 9, 2005 | 10:38 AM
ivanson's Avatar
Default Re: (d16vtecx)
Thanks for the help ppl but
i got it running now....
it was the starter cable from
the wiring harness the lil one...
it was dirty...forgot to clean that one.
now it starts on the first click...i used
limon to clean it...seriously
soto2635
Jan 15, 2009 10:44 AM
96_LS
Nov 29, 2006 10:00 AM
CiViC I2aCeI2
Mar 12, 2006 03:53 PM
HANABLE
Feb 27, 2005 05:40 PM
lowblazin
Nov 25, 2003 10:00 AM
