90 accord, rear windows dont work??
Guest
Posts: n/a
i have a 90 accord lx...the front power windows work fine, but the both rear ones dont work at all. thought i would post this here in case maybe this is a common problem on this year accords and see if anyone knows exactly what it is. i know on 86-89 accords its a common problem for them.. thanks
yes, one of the many downfalls of all gen, accords that i know of (not entirely sure if the 6th gen accords have same problems) since their newer they might not but i know that 5th gen and down usually run into problems with window motors eventually, its a bitch i know, i hated it too, so far i have replaced 3 of 4 window motors in my 97 lx, and the one i havnt replaced needs to be replaced bad, id suggest if you know what your doing taking your door panel off and having a look, if theres a problem with the motor youll notice it whether or not you know about the motor, just take the panel off and use the controls in the driver side door to try and push it up.. does the window atleast make a sound or is it completely silent? if its making a sound atleast the pullys could be damaged, if it isnt the motor could just be dead, doesnt really matter, either one of the two youll need new motors
I have a '92 sedan and was able to fix one of my right side power windows (both lefts work fine) by simply putting a new fuse in the box under the hood. Same thing w/ my power door locks.
khronicboy420
Jan 27, 2011 05:48 AM
manwezy951
Apr 2, 2005 09:14 PM
all420
Jul 11, 2004 09:32 AM
