Suspension & Brakes Theory, alignment, spring rates....
Ground control Top Mounts
Old Oct 8, 2005 | 08:05 PM
Rob.'s Avatar
Default Ground control Top Mounts
Will these top mounts work with my H&R coilovers ? I want some more
suspension travel.
Old Oct 8, 2005 | 09:36 PM
.water's Avatar
Default Re: Ground control Top Mounts (Rob.)
connect ground control. fast and easy
Old Oct 9, 2005 | 08:30 AM
Rob.'s Avatar
Default Re: Ground control Top Mounts (JunkyDC2)
So will they work ?????????
Old Oct 10, 2005 | 04:09 AM
xdrian's Avatar
yes they will fit
Old Oct 10, 2005 | 06:33 AM
jonshonda's Avatar
Community Builder
What do do mean you want more suspension travel? I don't think that the tophats will give you any more travel, they just take out more of the rubber bushings and help to make a better and more solid suspension feel. But i could be wrong
Old Oct 10, 2005 | 10:30 AM
Erik95LS's Avatar
Default Re: (jonshonda)
Just call or send Ground Control an email asking them. You'll have your answer in a matter of minutes and you'll pretty much know it'll be correct. Here I'll even be so kind as to get their number for you (530) 677-8600
These just give you a bit more shock travel so you can actually take advantage of the full range of the shock's movement.
Old Oct 10, 2005 | 11:33 AM
Jayboy's Avatar
Default Re: (Erik95LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonshonda &raquo;</TD></TR><TR><TD CLASS="quote">What do do mean you want more suspension travel? I don't think that the tophats will give you any more travel, they just take out more of the rubber bushings and help to make a better and more solid suspension feel. But i could be wrong</TD></TR></TABLE>
yes u are
Old Jul 11, 2009 | 12:22 AM
fc3srx729's Avatar
x2...
deviant1
Feb 29, 2004 09:27 AM
erikiksaz1
Feb 9, 2004 10:00 PM
j-robsDA
Jan 24, 2004 08:20 PM
Tad
Jul 28, 2003 11:41 PM
CXHatchback
29
Mar 11, 2003 05:34 PM
