What's the plug look like on a Stock Si Distributor???
Old Oct 8, 2005 | 03:12 PM
Josue's Avatar
Default What's the plug look like on a Stock Si Distributor???
So here's what I got on my plate now.....
The guy I bought my CRX off of called me and said he had an engine harness that came with the car. There was a ZC in it that the kid pulled out of and sold it to my buddy without a motor and he sold it to me the same way. He said the harness might work for my D16a6. so we tried and it seemed to be wrong. Had a x-tra plug by the Dist. plugs for the Cam Sensor? (is that right?) and one of the Dist plugs was like square and the other one was round.
Now, the Distributor on my motor came off of a 89 CRX Si( which is what I have) and it has One Big Round Plug and another Smaller Round Plug as well. Even the smaller of the 2 plugs is bigger than both of the plugs on the ZC harness. NOW we're not 100% sure if it is the Dist we think it is cause it was layin with a bunch of parts in a barn that ALOT of people go in and out of. We don't know many people with Si's around here that we could look off of to compare.
So can anyone give me a description of a stock distributor? Will that ZC harness work and we have the wrong Distributor? Or is that the right dist and the ZC harness simply won't work on a D16a6?? Thanks Guys...
Old Oct 9, 2005 | 08:17 AM
Josue's Avatar
Default Re: What's the plug look like on a Stock Si Distributor??? (Josue)
All the traffic on this site and No-one can go outside and look at their Distributor for me and tell me what the plugs look like?? C-mon Guyz!!!
Old Oct 9, 2005 | 10:31 AM
ef-lover's Avatar
first of all the stock distributor on a si is round, yours is going to be square. what u need is a wiring diagram and cut off that square one i went through the same thing. dont touch the small one that should plug right into the stock harness.
Old Oct 9, 2005 | 05:13 PM
Josue's Avatar
Default Re: What's the plug look like on a Stock Si Distributor??? (ef-lover)
Why do I need to cut stuff? This isn't a motor swap or anything, just putting a bone stock D16a6 back into a CRX.........So we should just be able to plug in the right harness to the right distributor and go. We just weren't sure if we had the right distributor or what.
Old Oct 11, 2005 | 08:29 AM
Josue's Avatar
Is this thing on??? No one has a 89 CRX Si they could look at real quick and just tell me what the plugs look like?
Old Oct 11, 2005 | 05:56 PM
jlicrx's Avatar
Si distributor plugs
DOHC ZC distributor plugs
Old Oct 11, 2005 | 06:40 PM
Josue's Avatar
Dude, THANK YOU!!!! I've been lookin and haven't found nothing. We got the right one then. Hopefully the harness I got will match.....
KevinEF7
Dec 24, 2012 12:34 PM
chase7687
18
Apr 19, 2012 05:57 PM
civic minime
Jul 31, 2006 10:28 AM
h22_crx
Jan 13, 2006 08:31 AM
turbo sol
Apr 28, 2003 11:08 AM
