Huge D-series Sale
Due to my overwhelming debt with the bank and income tax and the fact that I am quite likely going to be moving to Toronto next year I need to sell my d-series COMPLETE setup. Here it goes ...
Engine:
- 2 D16y8 heads (1 from ZEX_MAN off honda tech that he made 588WHP with supposibly valve springs, retainers, valves and keepers and the other head being stock) $200.00
- 1 spare D16a6 engine (complete bottom end that I was going to send out for sleeving, still ran great when pulled) $100.00
- BRAND NEW d-series starter and alternator $100.00
- d16 DC header - $80.00
- 6 SRP 9:1 pistons (4 brand new with rings and wrist pins and 2 used with everything needed) - $420.00 ... PENDING
- Brand new in box Eagle H-beam rods with 3/8's rod bolts - $$300.00
- ZEX 59300 street/strip cam (best d-series cam on the market at this time) - $250.00
- Brand new ARP Head studs and ARP rod bolts in packages - both - $120.00
- AEM Cam Gears
3bolt - $70.00
5 bolt - (brand new in box) - $130.00
- HONDATA intake manifold gasket (BNIB) - $80.00
- OEM HONDA PARTS (brand new parts)
- Head gaskets (x2)
- Oil pan gaskets
- Valve cover gaskets
- timing belts (x2)
- exhaust manifold gaskets
- intake manifold gaskets
- throttle body gaskets
- etc etc etc - All for $100.00
- Water pump - $60.00
- Brand New B&M adj. FPR and gauge set (silver new in box) - $40.00
- Brand new B-Series STR competition Fuel rail (bronze, new in box) - $120.00
Transmission
- 89-91 Civic/CRX SI
- SRR 4.7 final drive
- Quaife LSD
(needs a new input bearing, not a big job at all, can be used without it) - $600.00
- also have a spare tranny as well I will include with the deal
- Exedy Stage 2 clutch and pressure plate and release bearing (3 puck) - $240.00
- Lightweight flywheel - $60.00 or $20.00 if buy the clutch
- 6 axels all together (3 for each side plus many extras) - $80.00
REMAINING TURBO KIT
- Equal length exhaust manifold (stainless steel with a T3 flange)
- 3" mandrel bent stainless steel downpipe
- full 3" custom made stainless mandrel bent exhaust system from downpipe back I will include a brand new magnaflow stock looking muffler still in package (strait through design for max efficiency)
- 6x 444 CC injectors from a GTR skyline (all were flow tested and are perfect, had them on my turbo D16) - $200.00
- Vortech BOV - $150.00
-Charge pipes(on turbo D16 on EF chassis, very very nice stuff)
- 2.5" charge pipes from turbo to intercooler (Aluminum mandrel bent)
- 3" charge pipes from intercooler to intake manifold (Aluminum mandrel bent)
Let me know if you are seriously interested in anything, please IM me and BUMP kindly.
Modified by turbo_CRX at 10:04 PM 10/18/2005
Modified by turbo_CRX at 6:13 AM 10/20/2005
Engine:
- AEM Cam Gears
3bolt - $70.00
- Head gaskets (x2)
- Oil pan gaskets
- timing belts (x2)
Transmission
- Quaife LSD
REMAINING TURBO KIT
bolt pattern for the downpipe is 5 common T3, from a precision SC50 60/63. The manifold and downpipe are made of really really quality material and are very nice looking pieces, all pie cut mandrel bends. The downpipe also extends under the car until a bit past the oil pan with a stainless flange on it as well as 2 O2 bungs.
Who is Mr Robot?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo_CRX »</TD></TR><TR><TD CLASS="quote">that is the price for both heads, shipping will be extra but shouldnt be too much.</TD></TR></TABLE>
ok i have a buddy thats interested.. what all do they come with?
rollydc69
Mar 19, 2006 02:08 PM
rollydc69
Mar 19, 2006 02:07 PM
