--------k20 in a 90-93 integra? -------------
Old Oct 8, 2005 | 10:29 AM
gubr6837's Avatar
Default --------k20 in a 90-93 integra? -------------
I RECENTLY PURCHASED A 03 CIVIC SI THAT HAS BEEN TOTALED IN THE PASSENGER SIDE. CAR RUNS AND DRIVE BUT I WANT TO PUT IN SOMETHING LIGHTER. WAS WANTIN A 90-93 INT CAUSE I SPENT MOST OF THE MONEY ON THE SI AND CANT AFFORD A 94-01 TO PUT IT IN. IS THERE ANYWHERE THAT HAS MOUNT ADAPTERS FOR THE 90-93?
Old Oct 8, 2005 | 11:27 AM
stocker2shocker91's Avatar
I requested a short story for a title.
Default Re: --------k20 in a 90-93 integra? ------------- (gubr6837)
i have a 91 Teg and i asked the same question and was told they have not been made yet. but hopefully they will come out soon if they are even working on making them
Old Oct 8, 2005 | 01:09 PM
94integ_h22a's Avatar
Default Re: --------k20 in a 90-93 integra? ------------- (stocker2shocker91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gubr6837 &raquo;</TD></TR><TR><TD CLASS="quote">I RECENTLY PURCHASED A 03 CIVIC SI THAT HAS BEEN TOTALED IN THE PASSENGER SIDE. CAR RUNS AND DRIVE BUT I WANT TO PUT IN SOMETHING LIGHTER. WAS WANTIN A 90-93 INT CAUSE I SPENT MOST OF THE MONEY ON THE SI AND CANT AFFORD A 94-01 TO PUT IT IN. IS THERE ANYWHERE THAT HAS MOUNT ADAPTERS FOR THE 90-93?</TD></TR></TABLE>
honestly, you might wanna rethink that, the SI comes with a k20a3 thats 160 bhp "just a better stock motor than the b18b" it would be alot better for you to drop a b18c in a DA. Just my .02
Old Oct 8, 2005 | 01:18 PM
JDM-EJ1's Avatar
Default Re: --------k20 in a 90-93 integra? ------------- (94integ_h22a)
Why would you put it in a DA if you wanted it to be light? The EG/EF chassi is much lighter than any DA.
Old Oct 8, 2005 | 01:20 PM
JDM-EJ1's Avatar
Default Re: --------k20 in a 90-93 integra? ------------- (JDM-EJ1)
Oh, and h22a is right. For the money, a k20a3 isn't a good swap. Sure, it's a K series.. But you can get a b16a2 (99-00 Si motor) and you'll be getting the same amount of power.
Get a k20a2 (RSX Type S) motor and you'll be throwing down some good power at the wheels.
Old Oct 8, 2005 | 05:13 PM
projectTeG's Avatar
yea the k20a3 engines are jokes...i barely have to try and take them in my ls. but as for the mounts hasports suppose to be releasinging them at or after sema
Old Oct 8, 2005 | 08:48 PM
Chiggah's Avatar
Default Re: (projectTeG)
i hear K series handles boost well 500HP i believe!
Old Oct 8, 2005 | 08:55 PM
projectTeG's Avatar
Default Re: (Chiggah)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiggah &raquo;</TD></TR><TR><TD CLASS="quote">i hear K series handles boost well 500HP i believe!</TD></TR></TABLE>
ls,gsr,and itrs get to that level all the time.....but how long will it last? and what yal people are failing to understand is the k20a3s dont have the normal intake and exhasut 3 lobe vtec system. the the rsx-s and the tsx, and the new si have it, but the k20a3 the non-tsx k24's have a system similar to the vtec-e system which at 2500rps the engine goes from working one valve to working both and the exhaust doesnt change profile. im pretty sure i have errors in this post that i will correct tomarrow.
Old Oct 8, 2005 | 10:30 PM
Integra_drk's Avatar
guys, you have to remember, he already has the motor so buying a new one would be pointless.
Old Oct 9, 2005 | 07:00 AM
DaWhiteCoupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94integ_h22a &raquo;</TD></TR><TR><TD CLASS="quote">
honestly, you might wanna rethink that, the SI comes with a k20a3 thats 160 bhp "just a better stock motor than the b18b" it would be alot better for you to drop a b18c in a DA. Just my .02 </TD></TR></TABLE>
he most definatly has a good point.
Old Oct 9, 2005 | 11:57 AM
sykotic's Avatar
Default Re: --------k20 in a 90-93 integra? ------------- (00G s R_93Coupe R)
Your fastest and cheapest option would be to put it in a CRX, they are cheap, light, and hasport makes mount kits, axles, etc for a k-series swap into them.
Old Oct 9, 2005 | 12:29 PM
IntegraB18C's Avatar
Default Re: --------k20 in a 90-93 integra? ------------- (sykotic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sykotic &raquo;</TD></TR><TR><TD CLASS="quote">Your fastest and cheapest option would be to put it in a CRX, they are cheap, light, and hasport makes mount kits, axles, etc for a k-series swap into them.</TD></TR></TABLE>
This is true. Hasport also makes K-series swap mounts for the 88-91 Civic, 92-95 Civic, 94-01 Integra, and the 96-00 Civic.
Old Oct 9, 2005 | 07:15 PM
gubr6837's Avatar
Default --------k20 in a 90-93 integra? ------------- (gubr6837)
i know there are several other lighter cars out there to put it in but i was just wanting to be a little different. but because of price and availability of parts for this project i probably wont go this route. i did happen to just run across an 89 civic si with a locked up motor. i think im gonna jump on the deal of $400 b/c i know there is a world of parts for it. thanks guys for the feedback.
Old Oct 9, 2005 | 07:19 PM
Heylookits shawn's Avatar
i saw a post on here awhile ago, some company came out with cams for the k20a3.
i believe it was something like a 20 hp gain from just the cams alone.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra_drk &raquo;</TD></TR><TR><TD CLASS="quote">guys, you have to remember, he already has the motor so buying a new one would be pointless.</TD></TR></TABLE>
Old Oct 9, 2005 | 07:21 PM
Default Re: --------k20 in a 90-93 integra? ------------- (Heylookits shawn)
https://honda-tech.com/zerothread?id=1286168&page=1
theres the post
Old Oct 9, 2005 | 07:24 PM
JDM DERF's Avatar
very true. It would be cool to see a k-series in a DA tho.
Old Oct 9, 2005 | 08:54 PM
Default Re: --------k20 in a 90-93 integra? ------------- (DeityDA9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeityDA9 &raquo;</TD></TR><TR><TD CLASS="quote">
very true. It would be cool to see a k-series in a DA tho. </TD></TR></TABLE>]]
yeah it would be awsome to see, but i just thought that it would be a waste if he dropped a k20a3 when he could drop a b16 or a b18c and still have ac/ps on stock mounts on top of that. If he was dropping a k20a/a2, then that would be another story
Old Oct 25, 2008 | 10:25 AM
4door93civic's Avatar
i am currently putting a k20a2 into my 93 da integra i have found the complete mount kit from innovative motor mounts and the wire kit from rywire i am now looking for the shifter box.
the_wrath_of_Khan
Jul 31, 2008 01:24 AM
1SLOWlsTEG
35
Feb 7, 2005 11:59 AM
jdmcivicferio
Jun 10, 2004 08:58 AM
