Does AEM bypass valve lower your hp or torque?
Old Oct 8, 2005 | 09:05 AM
integracura's Avatar
Default Does AEM bypass valve lower your hp or torque?
I heard that having an aem bypass valve lowers your hp and torque, is this true?
Old Oct 8, 2005 | 09:20 AM
Is this true?
Old Oct 8, 2005 | 10:07 AM
1997GS-R's Avatar
i didn't notice any difference after i installed mine...but they say you lose a little performance
Old Oct 8, 2005 | 10:19 AM
TunerN00b's Avatar
Default Re: Does AEM bypass valve lower your hp or torque? (integracura)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integracura &raquo;</TD></TR><TR><TD CLASS="quote">I heard that having an aem bypass valve lowers your hp and torque, is this true?</TD></TR></TABLE>
Anything that slows down the flow of air will decrease performance. Then again, we're probably talking about losing 0.5 of the 1.5 whp that you got from it in the first place. I don't use a bypass, but if you're paranoid, go ahead and install one.
Old Oct 8, 2005 | 11:38 AM
Liquid Ice NF's Avatar
Default Re: Does AEM bypass valve lower your hp or torque? (TunerN00b)
i felt no decrease at all. i think there is one, but it is extremely small. but i feel a lot better when my cash splashes through deep puddles now.
Old Oct 10, 2005 | 09:28 AM
1997GS-R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b &raquo;</TD></TR><TR><TD CLASS="quote">
I don't use a bypass, but if you're paranoid, go ahead and install one.</TD></TR></TABLE>
you mean if you're smart...what's $50 when it could save your engine? if you're going to run a CAI do it right the first time.
Old Oct 10, 2005 | 09:33 AM
cm zak's Avatar
Yea, But remember if you run AEM V2 they dont have one for it, guess that means some of us are SOL.
Old Oct 10, 2005 | 09:38 AM
hatchback_guy's Avatar
the bypass valve is going to cost you a few hp across the entire rpm range, id rather just avoid puddles...
Old Oct 10, 2005 | 05:20 PM
4speedprotocolr's Avatar
Default Re: (integracura)
yes it is true... after i bought my aem bypass valve and before installing it on, i read the "directions..." something after that says will lose several horsepower. after reading that, i friggin returned that piece of shiet. my cold air intake (just two short ram pipes connected to each other) does fine in puddles... except this once where the puddle was up and over my friggin filter... my car died while going over it but it managed to pass the water. it took like two minutes to start up the engine and i didn't have problems. the only thing was that the water covered my filter so it couldn't suck any air. that's why it died... haha
Old Oct 10, 2005 | 11:53 PM
EnjoyTheRideDC2's Avatar
Default Re: (4speedprotocolr)
I say just keep your stock air box around and when the rainy season hits, swap it out. Its not like you're going to need that horsepower in the rain. The bypass valve is going to hinder performance, so might as well just put the CAI in the garage for the winter and drive a tad bit slower.
Old Oct 11, 2005 | 07:06 AM
ecks_fourttwo's Avatar
cai's are over-rated!
Old Oct 11, 2005 | 07:19 AM
redDAinteg's Avatar
Default Re: (ecks_fourttwo)
Short Ram. You lose throttle response with a CAI compared to a short ram. And I read from somewhere that once your going passed 30mph, it doesn't matter anymore.
Old Oct 11, 2005 | 10:53 AM
1997GS-R's Avatar
Default Re: (redDAinteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redDAinteg &raquo;</TD></TR><TR><TD CLASS="quote">And I read from somewhere that once your going passed 30mph, it doesn't matter anymore.</TD></TR></TABLE>
WRONG
Old Oct 11, 2005 | 11:33 AM
shamoo's Avatar
Will you make something up for me please?
Yes. Anytime there is a change in piping diameter, a restriction, etc, there will be a pressure change. There will be a loss in power. In this case, the amount will be negligible.
So technically the answer is yes. But the answer you're looking for is no.
Old Oct 12, 2005 | 03:27 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redDAinteg &raquo;</TD></TR><TR><TD CLASS="quote">Short Ram. You lose throttle response with a CAI compared to a short ram. And I read from somewhere that once your going passed 30mph, it doesn't matter anymore.</TD></TR></TABLE>
hmm, when did speeds in excess of 30 MPH determine the significant gains between a CAI and a SRI?
Old Oct 14, 2005 | 08:44 AM
yea i think im just gonna get a sri because check this out...
http://www.tprmag.com/issue/1/1_intakes.shtml
so i decided im getting a weapon-r intake and then i will just buy a weapon-r icebox for it.
Old Oct 14, 2005 | 08:58 AM
1997GS-R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integracura &raquo;</TD></TR><TR><TD CLASS="quote">yea i think im just gonna get a sri because check this out...
so i decided im getting a weapon-r intake and then i will just buy a weapon-r icebox for it.</TD></TR></TABLE>
umm the only thing wrong with that entire test was it was done on a dyno...the benefits of all the CAI systems come from driving...a dyno is never going to give accurate gains for a CAI system unless they can use a fan to simulate the rush of air to the filter at highway speeds
Old Oct 14, 2005 | 09:20 AM
yea that is true though, does anyone have their dyno results from just having a sri or cai, now that will tell you how much hp or torque you get from an intake, but then again u have to have a fan that stimulates highway speeds rush or air.
Old Oct 14, 2005 | 09:59 AM
no they did use a fan, but they said the sri suffered from heat stroke and the cai didnt.
Old Oct 20, 2005 | 11:45 AM
do u have to cut the intake to put a aem bypass valve in your aem v1 cai.
Old Oct 20, 2005 | 01:03 PM
1997GS-R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integracura &raquo;</TD></TR><TR><TD CLASS="quote">do u have to cut the intake to put a aem bypass valve in your aem v1 cai.</TD></TR></TABLE>
yes
Old Oct 20, 2005 | 04:25 PM
mjc1055's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integracura &raquo;</TD></TR><TR><TD CLASS="quote">they said the sri suffered from heat stroke</TD></TR></TABLE>
Hahaha, oh no! Somebody call 911!!!! We've got to get this intake to the hospital!
Old Oct 20, 2005 | 05:27 PM
vincepru's Avatar
can i just cut my CAI to make it a SRI, and clamp the rest on after winter and rain?
Markov
Oct 10, 2005 12:52 PM
TuCKiNaLL4s
Feb 3, 2005 11:55 AM
Slow*Jim
Aug 18, 2004 12:28 PM
aaaallll04
Jun 8, 2003 01:11 PM
