Gonna drain tranny...need help please
whatsup...im finaly starting to go about handling my car myself rather then letting other poeple mess wit it at shops....i gottta a b16 in my EK...and i been noticing a light grind at high rpms when shifting into 3rd...im gonna try to switch the tranny fluid to GM synchrormesh. i really dun wanna bring it to someone to change something as simple as that....so if u guys could kinda tell me what im looking for under the car and where it is....like a screw..bolt..etc...whatever it is....and where under the car it is....and once i drain it how many quarts will my b16 take??? thanks guys...ne help would be appreciated...
Look at this thread. You can see it's alot easier to fill the tranny through the VSS:
https://honda-tech.com/zerothread?id=382416
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underb00steg6 »</TD></TR><TR><TD CLASS="quote">oh and i believe it takes between 2&1/2 to 3 quarts to fill.
D series is 1.8. I'm not sure about B series but it's probably like 2.0. There's no way it's close to 3.
</TD></TR></TABLE>D series is 1.8. I'm not sure about B series but it's probably like 2.0. There's no way it's close to 3.
im pretty sure but not 100% positive ......but it takes a little more than 2 quarts. I know its not 3 quarts in between 2 & 3 quarts.
Yeah, it's on the passenger side. Jack the car up and lookunderneath. It's the one bolt that doesn't take a socket. The bolt has a round edge and has a big square in it. So you only put your ratchet in it.
