Anyone heard the rumor of a toda ecu coming out?
Old Mar 4, 2002 | 02:56 PM
done's Avatar
Default Anyone heard the rumor of a toda ecu coming out?
Ive heard of this rumor some where, and wondered if you guys have heard anything?
Old Mar 4, 2002 | 02:58 PM
Big Phat R's Avatar
Default Re: Anyone heard the rumor of a toda ecu coming out? (Jordo)
It's specifically designed for use { with Spec C's}* and the Sports Injection ITB's
Quote:
TODA RACING Sports Injection Kit
Available for: B16A, B16B, B18C Type-R
TODA sports injection kits vastly improve engine throttle response and power output through the use of one throttle body per cylinder. Effective tuning per cylinder is not compromised as with the standard one throttle body configuration of the factory intake manifold. Price: $2,650
Super response The improvement of the accelerator response is due to the
reduction in volume of air within the manifold.
Increased power Improved induction efficiency gives the engine the correct quantities of air/fuel on demand.
1. Each intake is made the same length.
2. Straight induction ports.
3. Individual throttle bodies are individually smaller in volume but collectively larger in volume. Giving both low- end torque and high-end power.
4. Airflow bench tested trumpet.
Bottom & mid range
Torque increase
Each cylinder receives a fuller charge of air/fuel especially at low to mid engine speeds.
This is due to the independent throttlebodies and more effective injector positioning.
*Technical Note: The TODA Sports Injection kit requires a fully programmable fuel injection computer, custom engine wiring harness, and injectors.
In approximately 6 months we will release a complete kit that includes the TODA Sports Injection unit, a custom wiring harness, and ECU.
Save up your pennies.
* - not sure about the cams but it's either C's or the VTEC Killers
[Modified by Big Phat R, 3:59 PM 3/4/2002]
Old Mar 4, 2002 | 03:02 PM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
Default Re: Anyone heard the rumor of a toda ecu coming out? (Big Phat R)
can you use those ITB's on the street? Not that I have that kind of dough...
Old Mar 4, 2002 | 03:03 PM
Mike M's Avatar
Founding Member
Default Re: Anyone heard the rumor of a toda ecu coming out? (Ross)
Come by this summer
Old Mar 4, 2002 | 03:10 PM
done's Avatar
Default Re: Anyone heard the rumor of a toda ecu coming out? (TypeRmsm)
very cool, something to look forward to
thanx guys
Old Mar 4, 2002 | 05:41 PM
t's Avatar
t
Does anybody know if the ecu will be from Toda or AKH ?
ken-e
Jul 26, 2010 07:55 AM
SOLOITR2001
May 7, 2007 05:17 PM
GUILOTINE
Oct 11, 2006 03:46 PM
S13 slide
May 16, 2002 07:31 PM
pinota
Mar 3, 2002 01:20 PM
