ALL Accord mounts good for H22 swap?
Old Oct 7, 2005 | 09:29 PM
JDM H22's Avatar
Default ALL Accord mounts good for H22 swap?
If I have an automatic 4th gen and I put a manual H22 in , can I use all of the original mounts. I searched but some people say you have to change certain ones and others say they bolt right up.
Old Oct 8, 2005 | 12:08 AM
4genaccordfreak's Avatar
^^ all the mounts will work perfect.. (EXCEPT FOR) the transmission mount.. which you will need a 5-speed accord mount for a 4th gen accord.. since the automatic mount will not match up
Old Oct 8, 2005 | 08:57 AM
JDM H22's Avatar
Default Re: (4genaccordfreak)
Thanks Bro
Old Oct 8, 2005 | 09:02 AM
JDM H22's Avatar
One more thing, the mount is bolt up right. No welding or cutting?
Old Oct 8, 2005 | 09:11 PM
no welding or cutting.. the only POSSIBLE custom work.. is unless you have an original 4th gen Prelude transmission mount.. (which you say you dont) there are 2 or 3 spots on the transmisson casting that just need to be threaded for the studs all fit properly.. but that is a very small adjustment.. to eliminate that.. try and find a 92-96 prelude manual transmission mount.. and it should and will.. bold right up.. no mods
areyouasian
Jun 25, 2024 05:52 AM
jfish
Oct 9, 2005 07:59 AM
Drag-Accord
Jan 17, 2005 02:59 PM
H23preludeSi
Apr 20, 2004 08:17 AM
crxzc
Jun 5, 2002 02:03 AM
