Need help with OBD2 LS Distributor
ok i have a 99 ls swap in my 92 civic hatch and i need a distributor. i buy one from this guy on honda tech and i get this. he says its an obd2 ls distributor but the plug doesnt match up. can any1 identify this and could there be a way to make it work. or do i have to buy another one. a friend said it is missing the plug that usually holds the Black/Yellow and the Blue Wires Which are power and ICM (Ignition Control Module (tach out)) respectively
i bought it from this guy.
this is the thread https://honda-tech.com/zerothread?id=1372626
this is the distributor that i need to replace.
this is the new one
Modified by BlackEG6 at 10:08 PM 10/7/2005
Modified by BlackEG6 at 10:09 PM 10/7/2005
Modified by BlackEG6 at 10:10 PM 10/7/2005
Modified by BlackEG6 at 10:11 PM 10/7/2005
Modified by BlackEG6 at 10:12 PM 10/7/2005
this is the new one
well, when i did my swap into my 99 coupe, i cut the plug from the existing EX harness and swapped the plugs............it worked for me........................use the plug from ur SOHC dizzy and match the wires ................
