VX 5 wire o2 harness to a 4 wire 02?
Old Oct 7, 2005 | 08:10 PM
90AccordVTEC's Avatar
Default VX 5 wire o2 harness to a 4 wire 02?
I recently swapped a d16z6 into my friends 93 VX and its running on the stock vx ecu and 5 wire o2 sensor. We tried hooking up the 5 wire harness to the 4 wire o2 sensor using advice from another HT member but we could not get it to work right. How can i do this conversion? Do i have to switch any ECU pins or wires in the shock tower harness? What wires do i use for the 4 wire o2, what slot do i put them in on the 4 wire plug and what do i do with the remaining wires left over from the harness? Any info and help is highly appreciated. Thanks.
-Chris
Old Oct 7, 2005 | 09:04 PM
howangseg's Avatar
Default Re: VX 5 wire o2 harness to a 4 wire 02? (90AccordVTEC)
bump cus im doing the same thing.
Old Oct 11, 2005 | 09:33 AM
Default Re: VX 5 wire o2 harness to a 4 wire 02? (howangseg)
Anyone?
Old Oct 11, 2005 | 09:44 AM
specv5150's Avatar
https://honda-tech.com/zerothread?id=1302696
This is how I did mine. The wiring colors will be different and the ECU pinouts may be as well. I only have expereince with OBD2 cars
Old Oct 11, 2005 | 10:18 AM
inline4's Avatar
http://www.hybridautomotive.com/tech/o2/
that's how I did mine.
when they say yellow/blk for the evap, injectors, iacv, I just ran a wire all the way to the top right of the engine bay and spliced into any of the yellow/blk wires for the relay(tons of yellow/blk wires running to the same plug)
p.s. I have a VX hatch too, with non VX motor.
Old Oct 12, 2005 | 05:24 PM
Default Re: VX 5 wire o2 harness to a 4 wire 02? (inline4)
Thanks alot for the info. Worked perfectly.
Combustion Contraption
May 30, 2011 10:50 AM
lowntegra
May 25, 2007 06:57 AM
b18vtecballa134
Feb 11, 2004 08:11 AM
Houston Hatchback
Apr 23, 2003 05:17 PM
Houston Hatchback
Apr 23, 2003 05:02 PM
