Please Give Some 5-lug Conversion Advice
Old Oct 7, 2005 | 07:25 PM
teranishi's Avatar
Default Please Give Some 5-lug Conversion Advice
Me again. Ok I searched for everything about the 5 lug conversion but nothing really helped. I want to know whats the best and or simplest way to do this. how much is roughly going to cost me. what parts do I need. and where I can get them. thanks.
Old Oct 7, 2005 | 07:37 PM
Redline96LX's Avatar
* B A N N E D *
Default Re: Please Give Some 5-lug Conversion Advice (teranishi)
SEARCH, i see this daily.
SIMPLEST WAY TO GET 5-LUGS:
Take your suspension apart, take it to a machine shop. press out the 4-lug hubs, and press in all four 5-lug hubs from a 97-01 Integra Type-R or a EK9 Civic Type-R. If 5 lugs is all you want, dont bother spending 1200$ buying what is essentially about the same exact knuckles and trailing arms. Now that you have 5-lugs, you'll need 5-lug rims, 5 lug rotors, and then research brake setups, cause you'll need at least a 10.4", but proably a 11.1" front brake setup, and 10.4" brake setup. I'd reccoment ITR or CTR brake setups for simplicity's sake, so the calipers, rotors, pads from a CTR, ITR, or search for other similar combos.
Old Oct 18, 2005 | 05:28 PM
go2sleep's Avatar
Default Re: Please Give Some 5-lug Conversion Advice (Redline96LX)
are you sure about the rear? the fronts would be fine, the rears, you might need to keep and eye on.
Zerolift-Robert
45
Mar 17, 2013 07:54 AM
MoreCowbell
23
Nov 15, 2011 02:48 PM
xsole
Jan 25, 2011 05:49 AM
Peake
Jul 23, 2007 08:44 PM
DC2_R
Oct 16, 2001 07:30 PM
