Tranny Oil
Old Oct 7, 2005 | 06:15 PM
Johnny_Rocket's Avatar
Default Tranny Oil
I just did a swap in my DA and I know it's probably a stupid question but everyone I ask tells me something different... What type of oil do I use in my 93 LS Tranny??
Thanks guys
Old Oct 7, 2005 | 06:25 PM
.swanny's Avatar
Default Re: Tranny Oil (JohnnyH)
Honda MTF
Old Oct 7, 2005 | 06:42 PM
Default Re: Tranny Oil (.swanny)
Do you know what weight that is? Honda wanted way too much for that ****... I just want to get Mobile or something and I just need to know what type to get.
Old Oct 7, 2005 | 07:14 PM
projectTeG's Avatar
you can run 10w30 non synthetic, but i just switched from regular oil to honda mtf and i could tell the shifter got alot smoother. its like 4.50 a qt here at my local dealer, and you need 2-2.3 qts
Old Oct 7, 2005 | 10:35 PM
gsr dood's Avatar
Default Re: (projectTeG)
i use 10w40 standard i cant find thaat honda mtf or syncrhomesh worked fine for years
Old Oct 8, 2005 | 01:38 AM
shorto85's Avatar
I run 10w40 full synthetic in mine and dont have any problems...
Old Oct 8, 2005 | 04:34 AM
ROOROWNS's Avatar
Toyota Auto tranny Fluid, in the Single Cam tranny. I replace it every two oil changes just to be sure its not getting sludgy, or too thin. The tranny used to grind third all the time now its only VERY high in the RPM's in 3rd.
I use toyota **** because its the easiest to get into the tranny when im at the dealership. No funnels or pump or anything just plug the nozzle in and push the trigger. Has worked great so far.
I saw that BMW guys were putting auto tranny fluid in their manual trannies because of the high heat properties. I also have another tranny just in case this one ***** the bed .
Sean
hamizle
Jun 29, 2009 11:55 PM
rEnZ94tEgGy
Jul 20, 2008 12:30 PM
xlusiveracer
19
Feb 5, 2007 05:57 PM
Zero4488
Jun 25, 2005 12:28 PM
mickey513
May 6, 2002 11:45 AM
