Help on messed up wheel
Old Oct 7, 2005 | 05:30 PM
s2k_al's Avatar
Default Help on messed up wheel
i have a 91 honda crx with an ls swap, and the other day i went to the track and i put on my slicks well whenever i dropped it back to the floor off of the jacks, i started to tighten the wheel when all of a sudden the whole wheel started moving forward. i was like wtf, the wheel was already touching the ground and as i tightend the wheel with the ratchet the whole wheel would move forward then back. does any body know what could be wrong with the wheel because the other wheel doesnt do this. please help. thanks
Old Oct 7, 2005 | 05:54 PM
s2k_al's Avatar
Default Re: Help on messed up wheel (s2k_al)
Old Oct 7, 2005 | 05:55 PM
tyro's Avatar
You mean the entire car moved forward, or just the wheel?
Old Oct 7, 2005 | 06:14 PM
s2k_al's Avatar
Default Re: Help on messed up wheel (tyro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tyro &raquo;</TD></TR><TR><TD CLASS="quote">You mean the entire car moved forward, or just the wheel?</TD></TR></TABLE>
just the wheel
Old Oct 7, 2005 | 06:22 PM
tyro's Avatar
how far forward?
Take the wheels off and compare each side, see if you find something missing or damaged.
Old Oct 7, 2005 | 06:24 PM
s2k_al's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tyro &raquo;</TD></TR><TR><TD CLASS="quote">how far forward?</TD></TR></TABLE>
like it would just turn forward like about an inch or 2
Old Oct 7, 2005 | 09:16 PM
s2k_al's Avatar
Old Oct 8, 2005 | 11:08 AM
s2k_al's Avatar
ttt
Old Oct 8, 2005 | 01:09 PM
sir90hatch's Avatar
Check to see if your suspension moves as well, sounds like maybe the crossmember bushings are bad, or the bar is not tightened in.
I recommend a aftermarket crossmember (traction bars) if you haven't got one yet.
Old Oct 8, 2005 | 01:34 PM
Lamchop0000's Avatar
yeh, my guess would also be a worn bushing or loose suspension bolts, vary possibly a cross memeber. maybe your wheel bearing is broken...
Is it clanking when your drive?
Modified by LamRacing at 3:47 PM 10/8/2005
Old Oct 8, 2005 | 11:11 PM
tyro's Avatar
Default Re: Help on messed up wheel (LamRacing)
make sure #5 is still there along with it's associated hardware..as usual, need more info!
cheers
Old Oct 9, 2005 | 06:42 AM
user 72830283's Avatar
yea take some pics of the suspension w/o the wheel on ofcourse...make sure the above picture corresponds correctly to your suspension
Old Oct 9, 2005 | 11:02 AM
mrtoastyjr's Avatar
Default Re: (pr3d)
could be a bad tie rod end, i would look at that before anything else. jack that side of the car up and try wiggling the tire from left to right and check for play.
DEEABLO
Jun 10, 2009 08:02 PM
HATCH DIS CATCH
Mar 26, 2006 10:29 PM
