Anyone running crower stage 3's?
Old Oct 7, 2005 | 12:59 PM
Pony_Fed95's Avatar
Default Anyone running crower stage 3's?
I just got my head done and installed. My set up is as follows:
B20B block stock except for ARP rod bolts and GE head studs
B16 head
CNC P&P
Crower valvetrain
Crower stage 3 race cams
Crower race valves
Bronze valve guides
skunk2 pro-series intake mani
RC 310 Injectors
Pro-Fab I/M gasket
AEM cam gears
What kind of numbers are you guys putting up?
Old Oct 7, 2005 | 02:07 PM
BrianSi91's Avatar
Default Re: Anyone running crower stage 3's? (Pony_Fed95)
i run stage 3's
1.8 ls vtec ctr pistons
210whp
Old Oct 7, 2005 | 02:24 PM
Tech6023's Avatar
Default Re: Anyone running crower stage 3's? (BrianSi91)
Stock pistons? I hope you have extra valves for the first time u hit vtec, Ive seen R cams put indents on b20 pistons
Old Oct 7, 2005 | 04:25 PM
Pony_Fed95's Avatar
Default Re: Anyone running crower stage 3's? (Tech6023)
negative, the pistons have valve relief
Old Oct 8, 2005 | 04:49 AM
F22PwrdS2k's Avatar
i run 3's in my H-motor...have been for a while now...never had a problem
Old Oct 8, 2005 | 10:25 AM
VtecDA9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrianSi91 &raquo;</TD></TR><TR><TD CLASS="quote">i run stage 3's
210whp</TD></TR></TABLE>
What other mods do you have? Do you think you are overcammed? I have similar setup and are looking for cams and I heard the crower 402 cams would be better???
81.25 ITR pistons B18A block
b16 head milled 30 thou
ITR intake manifold/64mm tb
DC-4-2-1
Old Oct 8, 2005 | 12:08 PM
onepoint6i's Avatar
Default Re: Anyone running crower stage 3's? (VtecDA9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecDA9 &raquo;</TD></TR><TR><TD CLASS="quote">
DC-4-2-1</TD></TR></TABLE>
go with the 403's if you sticking with crowers, if not try some RM cams or BC cams
ls_vtec_da
15
Jun 26, 2010 09:29 AM
lsvek9
15
Jan 9, 2006 05:30 PM
Mr. Samurai
14
Jul 3, 2004 03:47 PM
freakin
May 12, 2004 11:20 AM
GOLDBERG
May 18, 2003 10:20 PM
