obd2 to obd1
Old Oct 7, 2005 | 12:46 PM
jdmCivic925's Avatar
Default obd2 to obd1
im planning to buy a 1999 b16a2 obd2 put it in my 1995 civic coupe obd1...i was wondering wat do i need to convert the obd2 to obd1 to my civic.??....i neeed help
Old Oct 7, 2005 | 12:57 PM
donut.'s Avatar
you need obd1 injectors, distributor, and alternator.
Old Oct 7, 2005 | 01:18 PM
JDM-EJ1's Avatar
Default Re: (donut.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by donut. &raquo;</TD></TR><TR><TD CLASS="quote">you need obd1 injectors, distributor, and alternator.</TD></TR></TABLE>
And the harness, correct?
Old Oct 7, 2005 | 01:35 PM
cxSHOE's Avatar
Default Re: obd2 to obd1 (jdmCivic925)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmCivic925 &raquo;</TD></TR><TR><TD CLASS="quote">im planning to buy a 1999 b16a2 obd2 put it in my 1995 civic coupe obd1...i was wondering wat do i need to convert the obd2 to obd1 to my civic.??....i neeed help</TD></TR></TABLE>
depends on how legal you want to go.. i assume your in norcal. where hoods get popped alot.
so if you want to do it legal, it will need to be barred with the state, which means you will have to convert all wiring to obd2, and you will need to add teh obd2 diagnostic port aswell.
if you want to run the risk of getting pulled over, and then deal with the fines, let alone selling the engine later. then just convert the engine harness, alt, dist, etc. to obd1 and run a chipped p28 ecu with a jumper harness
DAP97SI
Mar 1, 2012 05:10 AM
bpoweredeg6
Mar 25, 2009 06:41 PM
QBANBOY407
Honda Civic (2001 - 2005)
20
Oct 9, 2007 08:28 PM
allshowaccord91
Nov 22, 2004 07:30 AM
92civic_si
16
May 6, 2004 02:50 PM
