Deep snow. Icy intersections. Advanced technology.
Perfect weather for tires!
Change your tires with the seasons. With winter tires mounted on their own wheels, you can install a seasonal Tire & Wheel Package yourself. When the weather changes, you're ready. When the seasons change again, your summer package goes back on. With it comes performance optimized for the season.
Take a look at The Tire Rack's Preferred Winter Tire & Wheel Package for the 2005 Honda Civic LX Sedan:
http://www.tirerack.com/a.jsp?...dClar=
Preferred Packages are the easiest way to outfit your vehicle for winter -- the ideal winter solution!
Our fitment specialists select a winter tire that best meets the performance level of your vehicle and add an affordable wheel option (usually alloy). Shipped to you mounted, balanced and with all the installation hardware you'll need, your Preferred Package is easy to bolt right on.
Preferred Packages are available for other Volkswagens as well. Or, you can build your own by selecting from the various tire and wheel (both steel and alloy) options that we have.
Read more about or build your own Winter Tire & Wheel Package here:
http://www.tirerack.com/a.jsp?...r.jsp
just get them from Discount Tire Direct, they have a ton of locations in Chicago too, so you could get them serviced at those stores. and YES a 14" wheel will fit your SI. there ARE however a few sizes you can put on the SI to keep your 15" wheels...they are called "plus zero" fitments and there are several tires to fit that...check into it.
With the 14 inch you will get better snow driving capability but will sacrifice a bit of dry road handling. The Dunlop Winter Sport M3 is the best combination of dry road and snow/ice driving that we sell. It will be a good choice since you are driving long distances.
FBP Si 2000
Jan 6, 2004 07:28 PM
