HELP... Vtec oil Pressure switch
Old Oct 7, 2005 | 01:40 AM
PaChiLa Leader's Avatar
Default HELP... Vtec oil Pressure switch
i need to wire this up to the ECU in order to have Vtec
i swap a 99 ITR motor in to 2000 LS
Knock sensor and Vtec Solenoid are both 1 wire so it's easy to firgure out but the Oil pressure has 2 wires Black and Blue i think
so which one do i wire to the ECu and what do i do with the other one?
thanks
Old Oct 7, 2005 | 01:54 AM
blackdelslo's Avatar
Default Re: HELP... Vtec oil Pressure switch (PaChiLa Leader)
you made 2 threads about the same thing
Usually black is always the ground.
Old Oct 8, 2005 | 04:45 AM
G2TegGuy's Avatar
Black is ground and Blue goes to ecu. Use the search function to find the ecu pinout you need to hook it to depending on what ecu you will be running.
tbgallant
Aug 16, 2013 10:41 PM
trickster kid
Aug 25, 2009 05:52 PM
NathanielH
Sep 1, 2006 09:33 PM
crxh22project
Jan 25, 2005 10:46 AM
b20b
Dec 14, 2001 06:58 AM
