Suspension & Brakes Theory, alignment, spring rates....
Brake swap
Old Oct 6, 2005 | 08:38 PM
SPOOLINmatt's Avatar
Default Brake swap
I have a CX and when i bought it, one side on the front has GSR, the other has CX brakes. Im gonna swap GSR brakes over to the CX, cant i just unbolt the caliper bracket and bolt it to the CX hub assembly and then change over the rotor as well. im trying to avoid having to pull the whole assembly out cause that would be a mess i dont need tomorrow.
Old Oct 7, 2005 | 09:10 AM
.RJ's Avatar
.RJ
Default Re: Brake swap (SPOOLINmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOOLINmatt &raquo;</TD></TR><TR><TD CLASS="quote"> Im gonna swap GSR brakes over to the CX, cant i just unbolt the caliper bracket and bolt it to the CX hub assembly and then change over the rotor as well. </TD></TR></TABLE>
Nope
Old Oct 7, 2005 | 03:14 PM
Stinkycheezmonky's Avatar
Suspetise...
Default Re: Brake swap (.RJ)
Yep, you need the whole GSR/LS spindle to use those calipers and rotors.
kabaroo
Jul 15, 2008 03:29 PM
t57b18
Dec 4, 2005 07:14 AM
northkai3
Aug 12, 2005 10:36 AM
05 S2K Stoner
Nov 12, 2004 07:49 PM
743power
Apr 21, 2003 04:53 PM
