b18c to ek swap problems: vtec solenoid
The shop who's doing my swap says that i need to get a new vtec solenoid. In every write-up that i can remember it always says to take the solenoid off of the outgoing engine, but when i told the mechanic this he said that the mounting is different. help.
are the d series and b series vtec solenoids ( same year, 97' ) the same?
Modified by FuNkDrSpOt at 8:23 PM 10/6/2005
What reason did they give you for needing a new vtec soleniod? And which one did they ask you to get?
My guess is that your d16 has the vtec soleniod with an oil pressure switch but the jdm b18 doesn't?
were you the one who emailed me with the same concern inquiring about my b16a engine i was selling?..still am selling by the way
shameless plug
http://www.craigslist.org/eby/pts/102427671.html
i'll call a buddy i know who owns a wrecking yard to see if he has a vtec solenoi for a b18c1
shameless plug
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redsun »</TD></TR><TR><TD CLASS="quote">What reason did they give you for needing a new vtec soleniod? And which one did they ask you to get?
My guess is that your d16 has the vtec soleniod with an oil pressure switch but the jdm b18 doesn't?</TD></TR></TABLE>
the second part is true but the reason he gave me was because the mounting ( holes for bolting it on ) was different. But i never heard of that before. Everyone who has done a swap keeps saying that the solenoid just ports over.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redsun »</TD></TR><TR><TD CLASS="quote">The solendoid should swap over. The solenoid that has reversed mounting holes is h22.
You dont need a new solenoid anyway because you can ypass the oil pressure switch.</TD></TR></TABLE>
so can anyone who has done a d16y8 to jdm b18c swap confirm that the V-Tec solenoids are the same?
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FuNkDrSpOt »</TD></TR><TR><TD CLASS="quote">
so can anyone who has done a d16y8 to jdm b18c swap confirm that the V-Tec solenoids are the same?</TD></TR></TABLE>Find out exactly what is wrong with it that they need to replace it. The entire assembly may be interchangable... However if it is the pressure switch (number 15 below) those are interchangable.. You will notice in the image the VTEC solenoid valve is removable, those are interchangable as well.
Is this shop reputable for swaps? Ask them if the CEL is a 21 or 22.
Modified by HondaFanatic708 at 12:59 AM 10/7/2005
nothing is wrong with it, its just that its a JDM b18c GS-R. I'm trying to B.A.R. it and the JDM vtec solenoid doesnt have the oil pressure sensor that i need to legalize it. I thought that the D16y8 solenoid w/ the oil pressure sensor was interchangeable with it.
I think its # 9
I think its # 9
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FuNkDrSpOt »</TD></TR><TR><TD CLASS="quote">nothing is wrong with it, its just that its a JDM b18c GS-R. I'm trying to B.A.R. it and the JDM vtec solenoid doesnt have the oil pressure sensor that i need to legalize it. I thought that the D16y8 solenoid w/ the oil pressure sensor was interchangeable with it.
I think its # 9</TD></TR></TABLE>Number 9 is the whole assembly. But the JDM VTEC solenoid isn't missing anything your USDM one has. This shouldn't keep you from passing BAR. Sounds like you should have taken your car somewhere else. The housing is different part number on a B-series but the pressure switch, that every VTEC car has, and the solenoid are interchangable between B and D series(Numbers 13 and 15).
Modified by HondaFanatic708 at 1:01 AM 10/7/2005
Actually the whole assembly may swap over, comparing images in my 97 service manual to the ones in my DC teg manual the mounting points look the same. I'm just thinking there us a small difference because 9 has a different part number while 13 and 15 match up when comparing the B18C to the D16Y8. I haven't tried to swap the whole assembly so I don't want to give you incorrect info. But you shouldn't have to change any of that if its functional..
ive already confirmed that the JDM housing isnt tapped for the oil pressure. Just like the JDM intake mani isnt tapped for the purge solenoid. I just need to get a new housing then i guess...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FuNkDrSpOt »</TD></TR><TR><TD CLASS="quote">can you tell me what the part # is for the housing? </TD></TR></TABLE>Number 9 is 15810-P30-005, but as I said what they are telling you is BS you don't need to waste the approx $250-$270 this will be from Honda new. The only reason to replace that is if the parts below the solenoid O-ring (number 14) were seized or broken (rarely happens). The pressure switch is no different. Part number 37250-PR3-003 on both the GSR and the D16 you have.. If your going to replace this even though there is no need, I might have one I could sell you. But I would feel bad, like I ripped you off because I sold you a part you already had that was fine.
so basically it breaks off into two parts, the oil pressure and the solenoid itself? The bottom part is the oil pressure and all i have to do is unbolt that?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FuNkDrSpOt »</TD></TR><TR><TD CLASS="quote">ive already confirmed that the JDM housing isnt tapped for the oil pressure. Just like the JDM intake mani isnt tapped for the purge solenoid. I just need to get a new housing then i guess...</TD></TR></TABLE>How have you confirmed this? The pressure switch is critical in the functioning of VTEC from what I understand. And you said that VTEC is working. If you wanna waste your money I'll check to see if I still have that laying around. I'll most likely be able to get to the garage this weekend.
Modified by HondaFanatic708 at 12:58 AM 10/7/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FuNkDrSpOt »</TD></TR><TR><TD CLASS="quote">so basically it breaks off into two parts, the oil pressure and the solenoid itself? The bottom part is the oil pressure and all i have to do is unbolt that?</TD></TR></TABLE>If you look at the image again number 15 is the oil pressure switch, 13 is the solenoid. These parts would come off the part that attaches directly to the head. There can be replaced with the ones from your old engine. Again these would only need to be replaced if you had a CEL (check engine light) or if the resistance in ohms between the 1 green/black wire of the solenoid and a body ground wasn't between 14-30 ohms. Again VTEC wouldn't be functional or have intermittant failure if that was the case. Wherever you "confirmed" that the GSR doesn't have a pressure switch is wrong, don't replace your ****. This would have nothing to do with BAR.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaFanatic708 »</TD></TR><TR><TD CLASS="quote">If you look at the image again number 15 is the oil pressure switch, 13 is the solenoid. These parts would come off the part that attaches directly to the head. There can be replaced with the ones from your old engine. Again these would only need to be replaced if you had a CEL (check engine light) or if the resistance in ohms between the 1 green/black wire of the solenoid and a body ground wasn't between 14-30 ohms. Again VTEC wouldn't be functional or have intermittant failure if that was the case. Wherever you "confirmed" that the GSR doesn't have a pressure switch is wrong, don't replace your ****. This would have nothing to do with BAR.</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=906684
the second to last picture
Yeah that solenoid pictured doesn't have the pressure switch. Every one I have ever seen has one. I just called a friend of mine who did a JDM GSR swap, his solenoid went and he replaced it with one from a 95 civic EX. He said both had the pressure switch though. He couldn't say if the 97 civic EX assembly would fit but again it may.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaFanatic708 »</TD></TR><TR><TD CLASS="quote">Yeah that solenoid pictured doesn't have the pressure switch. Every one I have ever seen has one. I just called a friend of mine who did a JDM GSR swap, his solenoid went and he replaced it with one from a 95 civic EX. He said both had the pressure switch though. He couldn't say if the 97 civic EX assembly would fit but again it may.</TD></TR></TABLE>
damn, so im back to square one because thats exactly what the shop recommended for me to do: buy one from an EG. Well do you know what the part # is?
damn, so im back to square one because thats exactly what the shop recommended for me to do: buy one from an EG. Well do you know what the part # is?</TD></TR></TABLE>15810-P08-005, again these are like $200-$250 from the dealer because I know list is like $275. I think your old one should work though because I have an EG and EK service manual and they look exactly the same in the illustration.
