will a crank pully
Old Oct 6, 2005 | 04:55 PM
89 pos's Avatar
Default will a crank pully
can a b18a crank pully fit a b18b
Old Oct 6, 2005 | 05:35 PM
Monaco's Avatar
Default Re: will a crank pully (89 pos)
Yes...B18a and B18b are pretty much the same engines.You can interchange any parts.
Old Oct 6, 2005 | 05:47 PM
LSTEG96's Avatar
Default Re: will a crank pully (Monaco)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Monaco &raquo;</TD></TR><TR><TD CLASS="quote">Yes...B18a and B18b are pretty much the same engines.You can interchange any parts.</TD></TR></TABLE>
not to be blunt
but absolutely not. sure, the pulley will fit on there just fine, but ur going to have issues. a major issue is when putting a b18a on a b18b. the b uses those teeth for the CFK sensor, and the a doesnt. get the right pulley. its expensive, it sucks, but its worth it. u dont want to have to wire up your dizzy to read the CFK and the cam angle sensor or whatever
Baby99EX
May 5, 2017 10:15 PM
tobe1424
May 18, 2006 08:30 PM
matthewchr
Oct 13, 2004 06:40 PM
LSintegra
May 27, 2003 08:07 PM
