Did b18c1 into a 97 civic hatchback. IACV problems.
Old Oct 6, 2005 | 04:42 PM
bcivichb's Avatar
Default Did b18c1 into a 97 civic hatchback. IACV problems.
I just dropped in a b18c1 into my 97 civic hatchback. I am having an iacv problem now. Im getting the engine code for it 2. The part is working and i wired it up but for some reason im still getting the code and when the car is warm the enine speed decreases or stall all together. Anyone had this problem before?
Old Oct 6, 2005 | 04:58 PM
kchungb17a's Avatar
Default Re: Did b18c1 into a 97 civic hatchback. IACV problems. (bcivichb)
Sounds like the part isn't working all the time. Happen to have a spare one out of a buddy's car you can swap in?
Old Oct 10, 2005 | 01:53 PM
bcivichb's Avatar
no i dont have a buddy with a spare. and that part is pretty pricy.
Old Oct 10, 2005 | 02:25 PM
Calvinator's Avatar
Default Re: (bcivichb)
Please check to make sure that you didnt mix up one of the harness plugs? It happened to me when doing my b18c1 swap. I blamed the iacv at first.
Old Oct 10, 2005 | 03:05 PM
bcivichb's Avatar
i checked all the plugs and there were some that were mixed up but iacv didnt even have one. I had to do the three wire-two wire conversion tho. ive checked that two and they are the wires i was supposed to use.
Old Oct 10, 2005 | 05:47 PM
BADD-EK's Avatar
Did you pop the wire & pin out of Plug A14 and put it into plug A12? When I did the IAC fix at first I didn't do that and It didn't work for me either.
Old Oct 11, 2005 | 07:43 PM
bcivichb's Avatar
Default Re: (BADD-EK)
Hmmmmmm... I didnt try that. Would i Have to do that even if i have the odbII-odbI conversion harness?
tomgreene
Jun 1, 2016 02:44 AM
EGEAZY
Feb 9, 2015 05:34 PM
94whiteSI
Jul 24, 2007 07:26 PM
fowler!
Jul 19, 2001 05:03 PM
