Have to ask.. h22 motor mounts
Old Oct 6, 2005 | 03:47 PM
jfish's Avatar
Default Have to ask.. h22 motor mounts
Doing the swap this weekend h22 5 speed in 97 accord auto what mounts to use. got the drivers mount from hasport. the h22 has one mount on it the right side.
Old Oct 7, 2005 | 02:47 AM
jfish's Avatar
Default Re: Have to ask.. h22 motor mounts (jfish)
bump
Old Oct 7, 2005 | 03:03 AM
The_Todd's Avatar
Farts in the shower
I believe you use accord mounts but for the tranny you use the lude mounts.
I'm going to try and look for ya though to confirm.
Old Oct 7, 2005 | 04:42 AM
v4lu3s's Avatar
RTFM
accord mounts.
using the driver side prelude mount with 3 seconds with a grinder is also cheaper than the hasport mount.
Old Oct 7, 2005 | 02:56 PM
jfish's Avatar
Default Re: (v4lu3s)
The h22 has the motor mount brackets on it front & rear. i can use them or do i need accord 5 speed ones. for motor mounts i have the lude trans mount & hasport drivers. can i use accord front & lude rear or accord f&r.
Old Oct 7, 2005 | 03:01 PM
TypeRKoncepts's Avatar
if u're converting to 5 spd u hae to use the rear 5 spd mount from either the prelude or the accord AND the 5spd bracket from either.
Old Oct 7, 2005 | 04:00 PM
slomofo's Avatar
GDD Member
Stock accord rear mount, 92-96 H22 lude driver's mount grinded to fit, Stock accord/H22 front mount, H22 trans mount.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">accord mounts.
using the driver side prelude mount with 3 seconds with a grinder is also cheaper than the hasport mount.</TD></TR></TABLE>
More like 3 hours.
Old Oct 7, 2005 | 04:30 PM
jfish's Avatar
Default Re: (TypeRKoncepts)
Ok so use the h22 brackets, lude trans mount, lude rear mount and accord front mount from 5 speed...
Old Oct 8, 2005 | 02:51 AM
jfish's Avatar
Default Re: (jfish)
bump
Old Oct 8, 2005 | 02:35 PM
v4lu3s's Avatar
RTFM
Default Re: (slomofo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slomofo &raquo;</TD></TR><TR><TD CLASS="quote">Stock accord rear mount, 92-96 H22 lude driver's mount grinded to fit, Stock accord/H22 front mount, H22 trans mount.
More like 3 hours.</TD></TR></TABLE>
I guess your grinder sucks *** then, or you dont have a clue what yo uare doing. but hey my experience is way diferent, 3 seconds is an exxageration, toal time was around 10-15 minutes o get it right for me.
Old Oct 8, 2005 | 04:00 PM
slomofo's Avatar
GDD Member
I use a die grinder, most people use a die grinder, you probably used a grinding wheel.
Old Oct 8, 2005 | 04:42 PM
jfish's Avatar
OK hasport drivers side , lude rear bracket & mount 5 speed 96 or 97 , accord front bracket & mount my year 97 5 speed, lude trans mount 5 speed. is this the ****.
Old Oct 9, 2005 | 07:59 AM
jfish's Avatar
Default Re: (jfish)
need help..
95accordh22a
Nov 22, 2006 04:06 PM
Drag-Accord
Jan 17, 2005 02:59 PM
jbonehead85
Jul 18, 2004 09:17 PM
Civichatch2k
Aug 9, 2003 04:55 PM
