9k rpm misshift, now car idles badly = fews question from the newbie
Old Oct 6, 2005 | 01:26 PM
b18option's Avatar
Default 9k rpm misshift, now car idles badly = fews question from the newbie
Hi honda-tech
Heres my problem. I did a miss shift at 9k rpm. The max i saw on the cluster was 9.5k rpm. So it probably rev a little higher. The engine, a JDM B18C-R, pulls great but idles like ****. The engine also make more noise( the little cliky heard on honda vtec engine) I know i probably bent a valvle or fucked up the adjustment of the valvles. My question is : Is it safe to drive the car and hit Vtec ? The car will be stored in 3 weeks and as i'm a student, I don't have the money to fix it now.
Thanks for answering
Old Oct 6, 2005 | 01:50 PM
boosted k20's Avatar
Default Re: 9k rpm misshift, now car idles badly = fews question from the newbie (b18option)
sounds like a bent valve to me. i would not drive the car aggressively at all (no VTEC)
run a quick compression test on the motor to verify this. is ur hearing knocking at idle and when u drive the car was well, then u probably bent a rod too or spun a bearing
Old Oct 6, 2005 | 02:10 PM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18option &raquo;</TD></TR><TR><TD CLASS="quote">Hi honda-tech
Thanks for answering</TD></TR></TABLE>
bent valves for sure. Check your t-belt, it may have jumped a tooth.
PS-I wouldn't drive the car at all. Drop valve=New motor
Old Oct 6, 2005 | 03:42 PM
Suck my DX's Avatar
u can do a compression test to see if ur compression is still good..psi readings shouldnt vary by more than 10-15 psi per cylinder...
if ur reading come out to lets say 220-220-215-210 that is ok...but if they look like this 220-185-220-215...then its time for a leakdown test to find out exactly where the air is escaping from...
Old Oct 6, 2005 | 04:14 PM
PURPLETERROR aka BIGMATT's Avatar
bent valves , do a compression test to verify
Old Oct 6, 2005 | 05:16 PM
greenbee's Avatar
Default Re: 9k rpm misshift, now car idles badly = fews question from the newbie (skunked)
t<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">bent valves for sure. Check your t-belt, it may have jumped a tooth.
PS-I wouldn't drive the car at all. Drop valve=New motor</TD></TR></TABLE>
if you must drive. check the engine thoroughly, first.
Old Oct 6, 2005 | 06:56 PM
b18option's Avatar
Default Re: 9k rpm misshift, now car idles badly = fews question from the newbie (greenbee)
Thanks for answering guys, greatly appreciated
Tommorow, i'll do a compression test. I hope for good numbers but ......
The engine don't seem to have lost power. Just this ******* valves noise and shitty idles
Right now, I drive the car lightly. Everything seems to be OK.
Old Oct 6, 2005 | 07:02 PM
Used2beAb16's Avatar
bent valve motor might run for a little while but if a piece of the valve or the entire valve would drop your gonna be in trouble so only drive it if its necessary but avoid if u can.
Old Oct 6, 2005 | 07:09 PM
skunked's Avatar
Default Re: 9k rpm misshift, now car idles badly = fews question from the newbie (Used2beAb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Used2beAb16 &raquo;</TD></TR><TR><TD CLASS="quote">bent valve motor might run for a little while but if a piece of the valve or the entire valve would drop your gonna be in trouble so only drive it if its necessary but avoid if u can. </TD></TR></TABLE>
Personally I wouldn't risk a $3K motor.
If it's running rough their bent pretty good.
Old Oct 6, 2005 | 07:58 PM
2quikmotorwerks's Avatar
yep you more then likely bent a few of your intake valves however it coulda also bent a few exaust cause the exaust valves like to float a little on a misshift, most of the cars that come into my shop for misshifting normally have bent exaust valves the intakes are fine but there is the ocasion when the intakes are bent or totally broke off stuck in the piston, but do what everyone else says check your compression and then a leakdown to back up your compression test
Modified by 2quikmotorwerks at 9:12 PM 10/6/2005
Old Oct 6, 2005 | 08:04 PM
mark_is_gay's Avatar
Default Re: (2quikmotorwerks)
why are u reving to 9k on a stock b18c? if power drops after 82k or so why are u up in the 9k numebrs? i dont get why people love to rev there **** as if it's a f1 motor...................
Old Oct 6, 2005 | 11:08 PM
StRoKeD-B16bEj2's Avatar
Default Re: (mark_is_gay)
idk man i have a B16b with just bolt ons and i rev to 9300 and it pulls it just isnt revving
Old Oct 7, 2005 | 11:11 AM
Default Re: (BLaCkMaNEg6)
have u dynoed ur motor to see where it makes peak hp? because it if stops at 85hundred rpms then i suggest u lay of the throttle........... no point to be up in those numbers if ur **** aint doing much, more stress, more problems
Old Oct 7, 2005 | 12:55 PM
k24a4kid's Avatar
I'm a Jackass
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mark_is_gay &raquo;</TD></TR><TR><TD CLASS="quote">have u dynoed ur motor to see where it makes peak hp? because it if stops at 85hundred rpms then i suggest u lay of the throttle........... no point to be up in those numbers if ur **** aint doing much, more stress, more problems </TD></TR></TABLE> exactly.....i loved reving mine to 9k allday.. well thats gone now
Old Oct 7, 2005 | 02:13 PM
Archidictus's Avatar
Unceasing Measure
Default Re: (turbofienD 04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbofienD 04 &raquo;</TD></TR><TR><TD CLASS="quote"> exactly.....i loved reving mine to 9k allday.. well thats gone now </TD></TR></TABLE>
Stupid is expensive isn't it?
Old Oct 7, 2005 | 02:54 PM
k24a4kid's Avatar
I'm a Jackass
Default Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">Stupid is expensive isn't it?</TD></TR></TABLE> no it's wasn't stupid.. it made power up their ..i would post a dyno put i dont have it no more..it was my falt tho for buying a head from a crack head.. i mean literly a crackhead.. the retainers gave and you could figure the rest
Old Oct 7, 2005 | 03:05 PM
VtecKiDD's Avatar
peak power is not the onley reason to rev high.
if you make peak power at 8200, and rev to 8600, then when you shift youll fall back higher in your power band in the next gear.
IE next gear youll be at 7200rpms instead of 6800, etc.
plus, the faster you get to your powerband and stay in it the faster you are USUALLY.
on a stock GSR 9000 is too much, but 8600 is perfect IMO.
my .02
Old Oct 7, 2005 | 04:26 PM
toEknEEg's Avatar
bent vavle... been though it before.
Old Oct 7, 2005 | 07:27 PM
skunked's Avatar
Default Re: (VtecKiDD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecKiDD &raquo;</TD></TR><TR><TD CLASS="quote">peak power is not the onley reason to rev high.
my .02</TD></TR></TABLE>
I agree. It's funny how many thought I was crazy reving my stock internal H22 to 8200-8300 rpms, peak power was much lower however keeping the revs higher when shifting to the next gear would net better ET's. I wouldn't recomend reving that high however it ran faster and that was a risk I was willing to take.
Old Nov 26, 2005 | 09:43 AM
PAndADc2's Avatar
Default Re: (ahbongkadah)
YUPS it hurts....and machine shop... took me 3 months!!!
Old Nov 26, 2005 | 10:07 AM
PLAN:B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLaCkMaNEg6 &raquo;</TD></TR><TR><TD CLASS="quote">idk man i have a B16b with just bolt ons and i rev to 9300 and it pulls it just isnt revving</TD></TR></TABLE>
now you know why your motor is fucked up
Old Nov 26, 2005 | 10:40 AM
dohcMONSTER's Avatar
Default Re: (PLANBmotorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLaCkMaNEg6 &raquo;</TD></TR><TR><TD CLASS="quote">...second the reason y the rotor fucked up is because the it has a shitty distributor, fuel pump, and spark plug wire...</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PLANBmotorsports &raquo;</TD></TR><TR><TD CLASS="quote">
now you know why your motor is fucked up </TD></TR></TABLE>
hahahaha no it's gotta be the plugs and fuel pump and dizzy.....haha
nvynuke18
Honda Civic (2006 - 2015)
13
Jan 28, 2011 03:50 PM
jiggatone
Jan 16, 2008 03:53 AM
nonv
Dec 3, 2004 08:11 AM
Geeq
Nov 15, 2004 10:21 PM
