Whats the main advantage of a tapered TB?
Old Oct 6, 2005 | 11:44 AM
Junkyard2000's Avatar
Default Whats the main advantage of a tapered TB?
Im guessing increased air velocity, but is there a certain size difference it needs? For example the itr is 66-62. Would it not be a good idea to make it 66-65, but thats not very tapered. Im looking for a good size for my b16 w/cams but dont wanna go too big. I wanna make it the same size as the IM inlet, which will be 64 or 65.
Old Oct 6, 2005 | 01:07 PM
chris_m's Avatar
* B A N N E D *
Default Re: Whats the main advantage of a tapered TB? (Junkyard2000)
If you want taper and a 65 mm plate you have to go billet. The honda throttle body only has so much meat. I do the taper throttle body for customers with mild applications and Im a huge fan of it. Throttle response and bottom end is not effected like the larger non tapered throttle bodies.
Old Oct 6, 2005 | 09:20 PM
Default Re: Whats the main advantage of a tapered TB? (Christopher M)
yea but how much of a difference(numbers wise) do they need to be? What about a 66-64(plate)?
fg2si!kid
Acura TL, RL & ZDX
Jun 26, 2008 03:57 PM
RACEPAK
Jan 27, 2007 12:40 AM
1hotcivicSi
Apr 7, 2004 08:41 AM
CRXRageD
Apr 19, 2002 08:48 AM
Eggman
Dec 31, 2001 09:22 PM
