Are manual and auto axles the same??
I was wondering if I would be able to use a axle from a manual transmission DA on a atuomatic transmission DA?? Both cars have ABS, only difference is ones a auto and the other is manual. Both are 91' GS's.
i'm 99% sure yes. i mean, autozone doesn't differentiate between manual and automatic axles for that car. they sell the same axle for manual as automatic, so they should be identical or so close that it doesn't matter. Acura has two different part numbers, but that doesn't mean the difference isn't basically zilch. you're probably asking this question b/c you can get a good deal, so take the good deal and if it doesn't work out then sell them again and get the right ones.
and i know for a fact that '94-'97 accords use the same axles, auto and manual. know i don't think you can interchange axles from one generation of teg to another, or generally from one car to another (accord to teg for example) but just auto to manual and vice versa for cars equipped with the same engine and same chassis then yes.
blackZC (W)
Dec 30, 2003 03:52 PM
