ok, when one radiator hose is warm and the other isn't? bad?
Old Oct 6, 2005 | 07:52 AM
EG93si's Avatar
Default ok, when one radiator hose is warm and the other isn't? bad?
ok, my car was driving fine, pulled up and my friend was like hey, your cars steaming, i looked and was like ****, i got to tighten that hose. i was about to go to class this morning and i check and they wern't lose. drove 4 miles to school, and was like 90% of the way up on the temp gauge. checked no steam. so i drive to autozone and fill it up with collent. starts overheating again, get it home, pop the hood, no steam, top radiator hose is hot, bottem, is cold. i know thats not good. what is its and what am i looking at
Old Oct 6, 2005 | 08:00 AM
Luserkid's Avatar
Default Re: ok, when one radiator hose is warm and the other isn't? bad? (EG93si)
Your thermostat isnt opening. Replace it.
Old Oct 6, 2005 | 08:02 AM
hondapwr's Avatar
Try replacing the thermostat and bleeding the system out when you're done. It sounds like things aren't circulating properly and the thermostat is usually inexpensive to replace yourself.
FYI, one radiator hose is supposed to be hotter than the other.
Old Oct 6, 2005 | 08:12 AM
EG93si's Avatar
i know, but one was like can't hold on to it hot (top) and the other was like burrr i live in ******* fargo and its snowing here)
Old Oct 6, 2005 | 09:36 AM
Targa250R's Avatar
be professional
Make sure to replace with an OEM Honda thermostat. Aftermarket units often have problems.
Old Oct 6, 2005 | 12:39 PM
EG93si's Avatar
Default Re: ok, when one radiator hose is warm and the other isn't? bad? (Targa250R)
ok, seal and thermo. replaced, heater works now but the only thing is it go through phazes of running hot and regular, is this because i filled it up but it wasn't on so it may still be a little empty, when i let it sit, it goes like half way between the top of the flag and the end of the actual bracket but when i take off it drops, my fans working now too, im guessing what that was
Old Oct 6, 2005 | 02:10 PM
JICEK9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">Make sure to replace with an OEM Honda thermostat. Aftermarket units often have problems.</TD></TR></TABLE>
Mugens are good. no problems ever.
Old Oct 6, 2005 | 02:18 PM
JDM-EJ1's Avatar
Default Re: ok, when one radiator hose is warm and the other isn't? bad? (Luserkid)
Sounds like the thermostat to me.
94GSRMR
Jul 5, 2010 07:50 PM
iHEARTMYCiViC
Jan 19, 2010 04:53 PM
Joseprz
14
Aug 25, 2009 05:05 PM
aj_scribble
Mar 20, 2008 10:28 AM
19992civichatch
Mar 1, 2007 10:49 AM
