Question about Air Conditioning, "K20 SWAP pics WOT!! WOT!!"
ok back last wenter a friend of mine did a K20 swap in his 95 GSR runs great and everything but, now he is going to school and is working also. he just wants car car ro drive around so he told me that he would trade me my 90 Si hatch, plus $5000. for his K20 integra. Well i told him if i can get Air Conditioning in the car that i would do the trade. so does any one know what all we would have to go about to do this any help would be GREAT THanks.
Isaac-
INTEGRA K-20A
95 Acura Integra
02 RSX type s engine and tranny
Hasport Motors Mounts
Hasport 400hp axles
Hasport wiring
Hondata Type S reflash
Clutchmasters Stage 3 clutch
Clutchmasters billet alluminum flywheel 8lbs
Hasport header
B&M Short Shifter
Injen Intake
AEM fuel pressure regulator
B&M fuel pressure gauge
Apexi' N1 exhaust
GSR Leather seats
Kenwood KDC-MP728
JDM Integra type r gauge cluster
Shunk 2 lowering springs
Poly bushings in all control arms
Aftermarket front sway bar with moog endlinks
let me know what you all think about the car
Isaac-
INTEGRA K-20A
95 Acura Integra
Hasport 400hp axles
Hasport wiring
Hasport header
B&M Short Shifter
Injen Intake
Apexi' N1 exhaust
GSR Leather seats
Kenwood KDC-MP728
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fergy016 »</TD></TR><TR><TD CLASS="quote"> 3K $3000. WHAT?</TD></TR></TABLE>
i had my 240's lines custom made to integrate the SR20DET a/c compressor to the factory 240SX's a/c system. cost ~$135 i think. NAPA is equipped to do this kind of work, BTW, so it's easy to find a place to do it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95lstegman »</TD></TR><TR><TD CLASS="quote">i had my 240's lines custom made to integrate the SR20DET a/c compressor to the factory 240SX's a/c system. cost ~$135 i think. NAPA is equipped to do this kind of work, BTW, so it's easy to find a place to do it.</TD></TR></TABLE>
thanks man, you've been the most help all day evey one else wants to bull **** around!
you're quite welcome. i think the bigger problem you'll run into is that during the swap the a/c is removed *i believe* because it doesn't fit. that may be your bigger worry. look where the a/c compressor goes and see if there is indeed room for it there. i could have sworn this swap was pretty much a no a/c swap. but that may just be because most people who do it want to race and racing and a/c don't mix well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95lstegman »</TD></TR><TR><TD CLASS="quote">most people who do it want to race and racing and a/c don't mix well.</TD></TR></TABLE>
well with this motor in this car it doesn't really matter, cause it will still be ******* fast!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spectrum24x »</TD></TR><TR><TD CLASS="quote">thats sexy.
Screw A/C i live in texas and never use mine.</TD></TR></TABLE>
don't you have a job? i like to show up to work at least looking and smelling okay. the windows just don't cut it for me. getting to work can be a little hair-raising sometimes and the windows just add noise. mwahahaha attack that tarmac . . .
tell him he needs to get this
http://www.karcepts.com/index_files/KSM000A.htm
how was installing the passenger side mount with the ABS in there?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BolivianDc2 »</TD></TR><TR><TD CLASS="quote">how was installing the passenger side mount with the ABS in there?</TD></TR></TABLE>
Easy!!!
Easy!!!
usdm k20 transmissions suck! they'll go out on you after awhile.. (the gears) you'll end up havin to get a whole new one, jdm k20 tranny's are tha bomb stuff though, they'll last you a lifetime!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ohsnapzafingcu »</TD></TR><TR><TD CLASS="quote">usdm k20 transmissions suck! they'll go out on you after awhile.. (the gears) you'll end up havin to get a whole new one, jdm k20 tranny's are tha bomb stuff though, they'll last you a lifetime!
who honestly has had one long enough to be able to prove that? if you're busting transmissions after only a few years either you've got enough power that NO 4-cylinder honda's FWD transmission is going to live up to the power, or you're a dumbass that doesn't like using the clutch to shift because you think you're cool and fast. i mean seriously, if you're having a problem with the gears doing anything other than stay nice then you've got issues either of huge horsepower or not being able to drive. the metallurgy of the transmission between JDM and USDM is probably identical, although admittedly i don't have any supporting data.
</TD></TR></TABLE>who honestly has had one long enough to be able to prove that? if you're busting transmissions after only a few years either you've got enough power that NO 4-cylinder honda's FWD transmission is going to live up to the power, or you're a dumbass that doesn't like using the clutch to shift because you think you're cool and fast. i mean seriously, if you're having a problem with the gears doing anything other than stay nice then you've got issues either of huge horsepower or not being able to drive. the metallurgy of the transmission between JDM and USDM is probably identical, although admittedly i don't have any supporting data.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ohsnapzafingcu »</TD></TR><TR><TD CLASS="quote">usdm k20 transmissions suck! they'll go out on you after awhile.. (the gears) you'll end up havin to get a whole new one, jdm k20 tranny's are tha bomb stuff though, they'll last you a lifetime! </TD></TR></TABLE>
Ive heard k20 trannys are crap too. No personal experience but ive read they cant hold alot of power.
you are right about the tranny thing , the tranny in the car has already been replaced once but is good for now!
well gears and synchros are NOT synonymous. we all know honda synchros are no good as a rule. i was wondering why the heck somebody commented that the gears aren't strong? it seems that since the K20's block is built like a tank, why would they skimp on the gears? i mean, drag racers with 500+whp blow gears, not people with stock turbo kits or bolt-ons and such.
just get the compressor off of a type s
a condensor from a civic (half length will fit nicely) and custom lines.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by low430 »</TD></TR><TR><TD CLASS="quote">ya I meant syncho problems but that means problem shifting into 3rd gear, The tranny holds power just has trouble shifting</TD></TR></TABLE>
welcome to the world of Honda. notice how the S2000 has a TRIPLE-cone synchro on first and double-cone synchros on second and third (and maybe more gears, i forget). all the lousy B-series gets is double-cone first on some models and single on the rest.
