what's my next best step??
Old Oct 5, 2005 | 08:49 PM
pomansouth01's Avatar
Ginger Kid
Default what's my next best step??
Ok, ill start by saying this, I have a ls/vtec, b16 head, b18 block. the following setup is making only 177whp and 126 tq.
things included in the build are as follows,
ITR intake valves
aebs intake mani
omnipower springs and retainers
bc3+ cams
fidanza cam gears
b&m fpr
rc 550 cc injectors
hondata managed
11.8:1 cr.(srp pistons)
eagle h-beams
z10 block girdle
lightened flywheel
act hdss
hondata manifold gasket (plastic im gasket)
ok, that is my motor,
now for my exhaust setup,
I have a dc 4-1 header with a 2 1/4 inch collector
2 1/4 inch piping through a highflow cat by magnaflow and magnaflow resonator
with a tanabe straight through muffler. I NEED to know what to do next in-order to get me closer to 200 hp.
thanks,
Steven
Old Oct 5, 2005 | 09:25 PM
Kendall's Avatar
I think you need to look into a more capable header/exhaust combo.
Also, what type of dyno was it?
Old Oct 6, 2005 | 05:02 AM
Phatch99's Avatar
Default Re: (Kendall)
your #'s seem low for that set-up. like kendall said what dyno?
Old Oct 6, 2005 | 05:37 AM
Ginger Kid
a dyno-jet, the motor had 500 miles on it at the time of dyno, maybe this has something to do with it, and also maybe it has something to do with the tuner...
Old Oct 6, 2005 | 09:05 AM
Black R's Avatar
25 Year Member
Default Re: (pomansouth01)
I would hit up the dAng guys... one of them works at a dyno shop in your area and can tune for you...
better i/h/e would help as well.....!
Old Oct 6, 2005 | 08:40 PM
Mushvroom's Avatar
yeah, with that setup , you should be able to 200 hp. Maybe the injectors should be 310? I duno, I've just researched that they are usually that.
but nice motor
Old Oct 6, 2005 | 08:58 PM
raffiT78's Avatar
Default Re: what's my next best step?? (pomansouth01)
well you should be making more power, a good person to contact would be B19coupe, that guy is making almost 244 hp to the wheel he has a post up called something like finally 244 whp at church's all i have to say is if he can do it, then maybe you should just go to the main source, i dont know the guy, have just wrote some posts in his thread, and he seems real cool. Dont be unmotivated there are plenty of different options for your motor.
Old Oct 6, 2005 | 09:54 PM
Ginger Kid
Default Re: (Mushvroom)
can you give me more information about these people, I wanna hit 200, so I have decided the next step will be, 2.5 inch mandrel bent exhaust with a magnaflow resonator and maybe tanabe muffler. Anyhow, its gonna be 2.5 inch all the way back. Also, I think I am gonna get a rmf or anr header, or maybe a tri-y design header. Anyhow, I am gonna hit the local dyno to see what difference it has made since its broken in and I played witht he cam gears a little bit.
Old Oct 6, 2005 | 10:35 PM
Icey112's Avatar
yes a better header
Old Oct 7, 2005 | 07:58 AM
Ginger Kid
bump to tell me if i have chosen right
Old Oct 7, 2005 | 09:09 AM
Phatch99's Avatar
better header and at least 2.5 inch exhaust with more tuning you should be able to hit 200+ whp....
xialbyix
38
Jun 5, 2008 03:31 AM
oldskool teggy
34
Feb 28, 2008 08:38 PM
Sp00nFed EM1
Mar 5, 2007 02:52 PM
yoorang
Sep 17, 2006 09:44 PM
TPB
May 12, 2006 06:32 PM
