will gsr lca's work with drum brakes?
Old Mar 4, 2002 | 08:17 AM
SoloSol's Avatar
Default will gsr lca's work with drum brakes?
right now I have a 92 cx need gsr lca's and gsr sway bar. I cannot afford to do the disc swap yet Will the rear drums work with the gsrs?
Old Mar 4, 2002 | 08:18 AM
DragII's Avatar
25 Year Member
Default Re: will gsr lca's work with drum brakes? (SoloSol)
drum and disk brakes use the same trailing arm.
Old Mar 4, 2002 | 08:34 AM
owen_the_soyboy's Avatar
Default Re: will gsr lca's work with drum brakes? (DragII)
I dunno about that,
but this is true-->drum and disk brakes use the same Lower Control Arm (LCA)
Old Mar 4, 2002 | 09:16 AM
Robster's Avatar
Default Re: will gsr lca's work with drum brakes? (owen_the_soyboy)
yes, gsr lca's will work with drum brakes, mounting points are the same between the 2 so don't worry about it. As far as the other comments, the trailing arms between drums and discs are the same, for a rear disc conversion you can just take the hub assembly off hte trailing arm and put the disc conversion and hub on there, however, because that is a real PITA and just keeping the rear disc on the trailing arms and putting that whole assembly on the car is a lot easier, so people just sell the whole assembly.
Old Mar 4, 2002 | 02:51 PM
SoloSol's Avatar
Default Re: will gsr lca's work with drum brakes? (Robster)
Are the delsol dohc vtec lca's the same as the gsr's?
iloveb16
Northwest (Sales)
Jul 6, 2009 05:20 PM
asianflava
Dec 8, 2008 11:14 AM
nemesismachine
Jan 30, 2004 04:39 AM
h22dc2
Aug 17, 2002 07:14 PM
