Need help fast!!! Locked key in car!!
Old Oct 5, 2005 | 07:26 PM
oilguzzler's Avatar
Default Need help fast!!! Locked key in car!!
Hey guys, i need some help unlocking my car. 2000 gsr with only the stock anti theft stuff. Its a canadian verison to. So what are my options? I need the car tomorrow morning! lol Every door is locked, but i have the hood open. I figure stealing tegs is pretty easy but i dont wanna go wrecking anything lol.
Old Oct 5, 2005 | 07:27 PM
memicah's Avatar
Default Re: Need help fast!!! Locked key in car!! (oilguzzler)
lol, that sucks man... bump for an answer to your problem!
Old Oct 5, 2005 | 07:28 PM
.water's Avatar
dude..just call the company who unlock the doors.
you dont have any spare key???
when i left my key, with alarm going on.lol i asked my friend to drive me home to get my spare key, alarm was going off 15mins str8.haha
Old Oct 5, 2005 | 07:29 PM
numbnuts22715's Avatar
i really dont think anyone is going to help you with the answer to this...hoods are pretty easy to open from what I hear without going into the cabin of the car, and getting in the hood is what helps theifs steal cars..
Youre gonna have to call a locksmith or something.
Old Oct 5, 2005 | 07:30 PM
DC_RaceR's Avatar
Default Re: Need help fast!!! Locked key in car!! (RED BUCKET)
Lock Smith around 35-50 bucks....
Dealer could make you another key
Old Oct 5, 2005 | 07:43 PM
PnoyJeff's Avatar
Default Re: Need help fast!!! Locked key in car!! (DC_RaceR)
get some kind of thin metal hook n pull up the lock from the window...i know that works on a few cars.. dont know bout a teg but it worked on my parents car n van
Old Oct 5, 2005 | 07:47 PM
DC_RaceR's Avatar
Default Re: Need help fast!!! Locked key in car!! (PnoyJeff)
use a penny on the key hole... It works on my Toyota..
Old Oct 5, 2005 | 07:49 PM
oilguzzler's Avatar
thanks for the replys, i aint no ****** theif or else id give myself a good kick in the ***, but i see how it is fom your point of view. Im gonna try to do the coat hanger trick, but i was assuming there be an easier way due to all the stolen tegs around.
Old Oct 5, 2005 | 07:51 PM
kuja's Avatar
I did that many, many times. Luckily the only time BOTH my keys were in the car i had the back of the sunroof cracked, and i mean cracked.. It took me a while but i got a coat hanger in and hooked it around my keychain and pulled the keys outta the ignition and up through the sunroof. woot ;D
Old Oct 5, 2005 | 07:55 PM
PnoyJeff's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC_RaceR &raquo;</TD></TR><TR><TD CLASS="quote">use a penny on the key hole... It works on my Toyota.. </TD></TR></TABLE>
are u freaking serious...im gonna try it on my moms corolla
Old Oct 5, 2005 | 08:04 PM
oilguzzler's Avatar
So it would be easier to get the key out of the ignition then unlock a door? would the passenger door lock be easier to open by any chance?
Old Oct 5, 2005 | 08:41 PM
Endless STi's Avatar
grab ur insurance card and head on over to the acura dealer. cost like 2 dollars for a spare key.
Old Oct 5, 2005 | 09:00 PM
Lauj87's Avatar
okay heres what you can do..but you have to be careful! you can brake you glass windows....get a flat head....use the flat head to flex the rubber linner on the top of the window....have a stick or long hanger ready, form this point use the flat to now flex the window just a bit enough to get the hanger through, now use the hanger to try and hit the botton! :-D worked for me just last weekend!
Old Oct 5, 2005 | 09:07 PM
f2rider's Avatar
Default Re: (Lauj87)
What I do is just pry the window back a few inches, jam a door stop in there (The triangle kind that looks like a piece of cheese or something), and then use a thin metal rod or something to hit the lock button. The door wedge just helps keep the window pried back so you have room to work.
My buddy called a locksmith once and this is all he did for about 70 bucks. We couldn't believe it was this easy.
Old Oct 5, 2005 | 09:32 PM
Desired_Speeds's Avatar
this might screw up your door trim, but take a coat hanger, and stick it through the area between the top of the window and the molding and pull the power lock button and walla, its unlocked
damn what I said is just like what u 2 just said ^^^
Old Oct 5, 2005 | 10:06 PM
Spectrum24x's Avatar
Default Re: (Desired_Speeds)
I'm a pro at the coat hanger trick, its fairly easy....
sometimes on some cars its a pain to get to the door lock, its a GSR, so you have power options, if it were an RS, sometimes you can roll the window down with a coat hanger, that works really well, but thats irrelevant..
It can be easier to get to the hatch release next to the drivers seat with a coat hanger, bend the hanger in a U shape at the end, loop that u shape around the very backside of that lever, lift, pop the hatch, put the seats down, crawl in and get your keys
*not a thief, just lock my keys in my car a lot.*
Old Oct 5, 2005 | 10:58 PM
bg-33p's Avatar
Default Re: (Spectrum24x)
slim jim
Old Oct 5, 2005 | 11:52 PM
Stimpeh's Avatar
slim jim is the way to go, really. however, i thought all integras could not be locked unless all the doors were closed, virtually eliminating any chance of getting the keys getting locked inside. or it could just be mine lol
Old Oct 6, 2005 | 01:38 AM
gsrvtec2's Avatar
Default Re: (skylinedo)
ahhaa its super easy. done it to my car twice wen i was high hahaha. first rip out that lil black rubber peice that protects ur window. den tkae a flat head and peel it on the edges. peel all the edges out and slowly pull out the window. dont pull it too far out as if it bends n will break. pull it out enuff where u can stick ur hand/antennae stick in it and unlock it. dats it
Old Oct 6, 2005 | 04:56 AM
oilguzzler's Avatar
Default Re: (tekneshum)
k thanks for all the help people! ill try that right now. Ive got 2 hours before im officially screwed lol.
Old Oct 6, 2005 | 06:02 AM
morocco's Avatar
Default Re: (Palmy Blue)
If you're using the hanger to unlock the door (just undo the hanger and feed it thru the window seal) meke sure not to scratch the window, it could suck really bad. Just put some masking tape over the end and feed it thru. Find the pulley to unlock the door (its usually near the button itself) and either pull it towards you or pull the hanger straight up. You may have to fiddle around for a few mins to get it, but it should work. BTW I know this b/c I did the same thing and found a hanger in the road to pull the lock with, in case you're wondering...Hope this isnt too late, good luck guy
Old Oct 6, 2005 | 06:25 AM
xteg95's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC_RaceR &raquo;</TD></TR><TR><TD CLASS="quote">Lock Smith around 35-50 bucks....
Dealer could make you another key</TD></TR></TABLE>
I think you need to bring a copy of the key to the dealer for them to make a copy of it.
Coat hanger always works for me...its that easy
Old Oct 6, 2005 | 06:28 AM
LL2009's Avatar
Default Re: Need help fast!!! Locked key in car!! (xteg95)
just fex the window stick your hand and unlock the car.
Old Oct 6, 2005 | 06:30 AM
tcteg's Avatar
Default Re: (morocco)
using a freinds integra key worked on my teg
Old Oct 6, 2005 | 07:25 AM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Palmy Blue &raquo;</TD></TR><TR><TD CLASS="quote">wow people are telling you some hard ******* ways to do that ****, the easiest way is to find another honda or acura and some toyota keys work to, stick it in the key holp partialy, strat jiggling it up and down while you are turning the key at the same time and pushing the key in slowly, it works 99% of the time....</TD></TR></TABLE>
yes accually that does work a kid i knows accord key can unlock and start my biddies accord....lol, and its opened another accords doors.
just dont do what i did and yank the door handle out of the door, becuase you locked out of a house with your keys locked in the cars a 3 in the morning
