holy n00b question! Si CD player into EG
Kid locally has a CD player out of his Si, his OEM one. Id like to put this into my EG.
Will this wire up normally? I had an aftermarket deck in there but it broke so i do have the harness' needed. Just wondered if they wire weird.
When I had one, I vaguely remember wiring it up to a newer, 99 Civic harness, and then it was plug/play. I picked up the harness from a local stereo shop, because it wouldn't just plug right in like the 92-95 stereo.
the si cd player needs the 98 up honda plug to fit it you can pick one up at any best buy metra 71-1721 should be the right number its a reverse harness. it will wire to the metra 70-1720 style harness you already have.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monicle »</TD></TR><TR><TD CLASS="quote">96-98 and 99-00 plugs are different. you will need to connect an eg aftermarket harness to an si pigtail. heres a part number for you. </TD></TR></TABLE>
thanks, that is what i thought.
Good info.
Good info.
NHBP-FA5
Mar 2, 2009 12:03 AM
eg6Nrps13
Jul 27, 2005 11:00 PM
badasshatchhh
Apr 30, 2005 02:49 AM
