Honda S2000 Honda S2000
Does it get any louder with just the test pipe?
Old Oct 5, 2005 | 04:30 PM
darmaintenance's Avatar
Default Does it get any louder with just the test pipe?
I have a stock S2000 and want to put in the test pipe. Just wondering how much louder does it get. I also want to put in the AEM v2 later on.
Old Oct 5, 2005 | 05:00 PM
papa5murf's Avatar
Default Re: Does it get any louder with just the test pipe? (darmaintenance)
yes it will get louder and deeper .... if you have an aftermarket exhasut, it reduces the drone on certain exhaust systems..
Old Oct 5, 2005 | 05:05 PM
Default Re: Does it get any louder with just the test pipe? (03s2kblue)
Thanks - do you know of any HP gains?
Old Oct 5, 2005 | 06:13 PM
01-0720's Avatar
so you want to put a test pipe on your stock car? why?
sounds to me like youv got a stock header and a stock exhaust, why whould you put a test pipe on your stock system, thats not going to do anything, your stock exaust isnt goin to get any louder, im mean it might be a tad different sounding but it will just sound stupid and you will gain no power at all, i whouldt be surprised if you lost power the way these cars are
Old Oct 6, 2005 | 02:12 AM
Default Re: Does it get any louder with just the test pipe? (01-0720)
I would like to free up the exhaust a little and put in the AEM v2 intake.
Old Oct 6, 2005 | 04:50 AM
01-0720's Avatar
a test pipe with the stock header and stock exhaust is not going to free up any power, its going to be a waste of money and time
Old Oct 6, 2005 | 09:29 AM
Mr. Projekt's Avatar
* B A N N E D *
Put your AEM V2 on first, enjoy it. Put the test pipe on when you get header and exhaust.
Old Oct 6, 2005 | 11:01 AM
Nishant's Avatar
Default Re: Does it get any louder with just the test pipe? (Sideways2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sideways2000 &raquo;</TD></TR><TR><TD CLASS="quote">Put your AEM V2 on first, enjoy it. Put the test pipe on when you get header and exhaust.</TD></TR></TABLE>
agreed
Old Oct 6, 2005 | 11:52 AM
c17r15's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01-0720 &raquo;</TD></TR><TR><TD CLASS="quote">a test pipe with the stock header and stock exhaust is not going to free up any power, its going to be a waste of money and time</TD></TR></TABLE>
actually it will. do you have a s2000?
Old Oct 6, 2005 | 12:03 PM
IHateJDM's Avatar
Default Re: Does it get any louder with just the test pipe? (c17r15)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c17r15 &raquo;</TD></TR><TR><TD CLASS="quote">
actually it will. do you have a s2000?</TD></TR></TABLE>
barely. your exhaust only flows as well as the most restrictive part. with a stock exhaust setup, that will be your cat or muffler. You may gain a fraction of an HP with a test pipe on stock exhaust, but you won't see much of a gain unless you replace the header and catback too. Also, this is true for any car, I don't see why you have to own an s2000 to understand this.
Old Oct 6, 2005 | 12:19 PM
c17r15's Avatar
Default Re: Does it get any louder with just the test pipe? (IHateJDM)
the muffler"S" are not restrictive.
anyway this is not about power, but sound.
with the test pipe the car will be louder as well as raspier...like a raspy 350z/g35. you could acheive the loudness without the raspiness by simply removing the resonator.
Old Oct 6, 2005 | 12:28 PM
01-0720's Avatar
or you could not be a cheap loser and just buy a freakin aftermarket exhaust and header to go along with the test pipe you want
Old Oct 6, 2005 | 12:33 PM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c17r15 &raquo;</TD></TR><TR><TD CLASS="quote">the muffler"S" are not restrictive.
No matter how you put it, two twin-loop mufflers aren't going to flow as well as a single straight through. Switching from a dual to a single doesn't necesarily increase any power, it just shifts the torque band a bit. With my exhaust, I notice a bit of sluggishness under 2500 rpm, but response and torque at 4000-6000 is a bit better according to the butt-dyno. I'm guessing somewhere around 3-4 lb/ft of midrange. Top end flow is a bit harder to gauge with VTEC, intake, exhaust all screaming at the same time, but I bet its 1-2 hp there too.
And then there's the whole weight savings thing...
Old Oct 6, 2005 | 03:54 PM
papa5murf's Avatar
thats where you're wrong... ... it's amazing to me when people that don't even own an s2k think they know all about it....
we all know the s2k's i/h/e setup from the factory is very efficient..... getting aftermarket i/h/e doesn't really give you much hp.. you'll be lucky to get 15hp out of those three components without tuning...... however there are some slight exceptions.. (j's header + j's 70mm header back being the best of the group) and we all know single exhausts give more power then duals......
but when you think of biggest bang for the buck.. a test pipe is better then all three.. and it's been proven..... $100 bucks for a test pipe.. matched up with a stock header and exhaust will give you around 3-5rwhp.. (there are dyno sheets on s2ki).... and there's dynos of a test pipe adding up to 10rwhp or so on a car with an aftermarket header and exhaust.....
Old Oct 6, 2005 | 04:04 PM
dkim48's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03s2kblue &raquo;</TD></TR><TR><TD CLASS="quote">
i was going to say the same thing...i will add this. the t1r dyno that was around a year ago showed that the test pipe alone made most of the power...i just can't justify making the people that drive behind me suffer...i hate being behind old cars that spew smoke and unbreathable air. maybe i'm just getting old
Old Oct 6, 2005 | 04:54 PM
Default Re: Does it get any louder with just the test pipe? (dkim48)
Will you get the check engine light to come by putting on the test pipe?
Old Oct 6, 2005 | 05:53 PM
Infinity_Racer's Avatar
yeah the s2k's i/h/e set up is far from your reg. B series set up...the exhaust and header is already well made from the factory so please stop spreading false information or information you have no idea about...
and yes, the test pipe WILL cause a cell unless you get the plug fouler or get this from s2ki...i think the GB is over, but its about 125 shipped from what he told me...
http://www.s2ki.com/forums/ind...21104
Old Oct 6, 2005 | 09:55 PM
Shift@9k's Avatar
Default Re: Does it get any louder with just the test pipe? (Infinity_Racer)
ill add this, i wouldnt knock the guy for putting a test pipe on his stock car. a stock with a test pipe Should gain power,especially with a v2 on the other end. Also i dont understand all of you guys saying the stock manifold NEEDS to be replaced to benefit from a test pipe, thats absoloute BS. There are maybe 2-3 header i would conisder better then stock, therest are all dogsh*t. i would recdomend header in this order 1. J's racing, because bigger is better on this car i dont care what the hell you half to tell me about back pressure, its all bs i have done like 30+ dyno runs to know. 2.toda,well shaped nice size, all around good but for the minimal price diff. between the two i would by J's all day. 3 mugen to high price,all for the name but does gain. As a stockcar site the absolute most restrictive thing in the exhaust system is the cat, thus putting a test pipe in should make a nice difference. I would recomend installing a V2 at the same time, all of that should be like 300.- and i would expect a 10hp gain, if car (motor) in tip top shape.
Old Oct 7, 2005 | 12:08 AM
revhi's Avatar
The berktech test pipe is still going for 100 bucks shipped, I just got one. Hoping I wont shoot flames
Old Oct 7, 2005 | 06:58 AM
Default Re: (revhi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by revhi &raquo;</TD></TR><TR><TD CLASS="quote">The berktech test pipe is still going for 100 bucks shipped, I just got one. Hoping I wont shoot flames
oh it is?!? guess i'll get one today...i thought he told me it would end by the end of sept...
that'd be nice if you did shoot flames
Old Oct 7, 2005 | 12:57 PM
papa5murf's Avatar
Default Re: (Infinity_Racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Infinity_Racer &raquo;</TD></TR><TR><TD CLASS="quote">
that'd be nice if you did shoot flames </TD></TR></TABLE>
he extended it to the end of this week i believe
Old Oct 7, 2005 | 01:04 PM
WowOzYouRock's Avatar
Default Re: (03s2kblue)
my local shop made me one for 120 install ... made of stainless steel pipe and bolts ... now my J's 60 rs sounds a lot deeper and im loving it ... but the secondary o2 sersor isnt too happy lol
Old Oct 7, 2005 | 02:26 PM
* B A N N E D *
Default Re: (Y2K_S2K)
Did you use the spark plug fouler trick? I know using 2 makes ur car runs a bit rich, 1 leans it out a bit but still keeps the CEL away.
Old Oct 7, 2005 | 02:47 PM
Default Re: (Sideways2000)
nah i didnt bother ... the car is going for storage this winter and next year time AEM EMS and wide band and some other new stuff ... stay tuned
Old Oct 7, 2005 | 02:53 PM
* B A N N E D *
Stay tuned? I will BE tuned. =D
EMS is the expensive and right way to solve your problems. The spark plug trick has been tried with success (AP1 in sig), so I was just recommending it.
