90dx with si engine cuts off about 3000-4000rpm
i m about to buy a 90 dx hb with a 90 si swap!!!! the car runs and starts but it wont go over 3000-4000rpm (no tach) i think the car ran good b4 but now it runs like sh*t ... mayb is the dpfi to mpfi??? but the car ran b4!!!! sum guy told me it was sum cable in the trans that was broken so it sent wrong codes to the car?!
p.s. NO CHECK ENGINE LIGHT WTF
yes my friend did a swap in his hatchback and he couldnt drive past 4000 rpm and it was the distributor
it is the distributor or the ecu for sure
ok i remember what it was i had this prob.. its one of ur wires on the distrubitor. one of the sesor wire isnt connected or loose somewhere. check all ur connection..
change the dist and ull be set if its the igniter thats easy to but i think its another part inside i forget witch it is last time we did a zc swap we had the same problem ran great for a week than the thing did the same thing cut off at 4 grand changed the dizzy and problem solved
Replace a bunch of parts until it's fixed- just like everyone else said
Seriously- which fuel injection are you running on this thing? How was the wiring done (if it was). Which ECU- we need more info. If you have a distributor laying around go ahead and swap it in to see if it helps. Auot or 5spd?
[Modified by fixhondas, 5:24 PM 3/6/2002]
From: PhantomGrayEH2, CA Where Gay Arnold Rules, USA
Same thing with my car, one u hit around 3500 it jumps and doesnt accelerate, it was the distributor cables that were not making any contact, they charged me $15 and Im extremely happy how it runs now. Good luck
Forgot before i fixed the problem I got a new coil, cap and rotor, plugs, cables and didnt make a difference. Not saying to not replace the parts, but honestly take it to a mechanic because once u decide taking it youll waste serious money replacing all these parts. It shouldnt be anything too serious
sorry man, I had some mechanic do the job for me. The only thing I could do to a car is a tune up. Sorry about that
u wont get one>!!!
rev limit hesitation at around 3-4k rpm, with normal startup and idle is ....
look up..!!
dont spend money on a distributor u dont need.!!! just replace the ignitor
and off u go!!
dano670
Oct 27, 2008 12:13 PM
classciv
Apr 2, 2006 03:30 PM
bigcalidave
Jan 24, 2006 02:06 AM
