Removing Stupid sticker line off your car!??!?!?!?!
Old Oct 5, 2005 | 02:06 PM
h22xcivic's Avatar
Default Removing Stupid sticker line off your car!??!?!?!?!
does anyone know a easy way to get that stupid ugly sticker line that runs down your car without damaging the paint? and also remove sticky glue thats been there for years? ANY HELP WOULD BE APPRECIATED!!!
Old Oct 5, 2005 | 02:08 PM
The Hooligan's Avatar
From: spinning DnB till your head explodes,jersey/philly
Default Re: Removing Stupid sticker line off your car!??!?!?!?! (h22xcivic)
use a heatgun to heat it up and use a lil goo gone for the sticky residue.
Old Oct 5, 2005 | 02:20 PM
h22xcivic's Avatar
Default Re: Removing Stupid sticker line off your car!??!?!?!?! (floss)
I TRIED using a steamer and that didnt help...i don't have a heat gun is there any kind of chemical or and kind of tool that i can use?...thanks
Old Oct 5, 2005 | 02:25 PM
nocturnaldragon's Avatar
Lacquer thinner,
lol kidding dont use that unless you want to take the paint off too.
Old Oct 5, 2005 | 02:39 PM
eJone powereD's Avatar
when i removed the stripe off my car, i used really hot water...used a towel with the hot water and ran it on the stripe a few times...then i just peeled it with the tip of my fingernail...if that doesnt work, try a blow dryer
as for removing the glue residue, i used 3m citrus adhesive remover...not sure where to get it since i found it lying inmy garage, but it's in a can and you jsut spray it on and wipe until its gone
Old Oct 5, 2005 | 03:01 PM
phthalo's Avatar
GDD4LIFE
Default Re: Removing Stupid sticker line off your car!??!?!?!?! (eJone powereD)
goo gone and a blow dryer is all you need
Old Oct 5, 2005 | 03:03 PM
Kamin's Avatar
Default Re: Removing Stupid sticker line off your car!??!?!?!?! (phthalo)
goo gone, bug and tar remover, etc.
just be sure to rewax afterwords.
Old Oct 5, 2005 | 03:05 PM
Street Ghost's Avatar
Default Re: Removing Stupid sticker line off your car!??!?!?!?! (Kamin)
When I did mine a few years ago, I used a blow dryer to heat it up a little bit and then just peeled at it with my fingernails. Then I used Goo Gone for the sticky residue afterwards. It took a little while and left my fingertips numb, but it worked.
Old Oct 5, 2005 | 03:17 PM
Kyles ej1's Avatar
Default Re: Removing Stupid sticker line off your car!??!?!?!?! (Street Ghost)
when i tried this with a hair dryer it worked for one side, i guess theother was on the car too long and it didnt come off
Old Oct 5, 2005 | 03:51 PM
JDM-Civic-Hatch's Avatar
longblock w/300 grit
ekcivic9's Avatar
pin stripe removal wheel + dremel. ate it right off.
Old Oct 5, 2005 | 03:54 PM
AbitAvenger's Avatar
like everyone said, blow dryer and some elbow grease
Old Oct 5, 2005 | 03:57 PM
Bon's Avatar
Bon
take it easy when rippin the strip off, dont do what i did and took a layer of paint off
the hot water idea sounds good
Old Oct 5, 2005 | 07:12 PM
dohctor_B's Avatar
Default Re: (Bon)
Some guy i know told me to use WD-40. wtf
Old Oct 5, 2005 | 07:36 PM
thestandardh's Avatar
easy---- Heat Gun and plastic razor blade--- yes plastic razor blade can buy anywhere or sometimes comes in packs of normal razor blades---- or eraser wheel on drill or dremel tool but move fast can burn paint quickly.
Old Oct 5, 2005 | 09:09 PM
JDM_FRONTIN's Avatar
* B A N N E D *
Default Re: Removing Stupid sticker line off your car!??!?!?!?! (thestandardh)
i worked two summers in a row takeing big ryder stickers off their moving trucks and what i found best to use is pretty much like everyone said was a blow dryer or heat gun, or if you can find something that heats up hotter, you may get away with just using that becasue the glue doesnt always stick to the car if heated enough.
Old Oct 5, 2005 | 09:17 PM
NerveAgent's Avatar
hair dryer and goo gone!
Old Oct 5, 2005 | 11:42 PM
h22xcivic's Avatar
wow thanks for all the reply's!!!!!!!!!!!
i find this site alot more helpful then the one on superstreetonline.com....those guys are jerks and haters!!!!!!!!!!!!!!!!!!
Old Oct 5, 2005 | 11:48 PM
Kyles ej1's Avatar
Default Re: (h22xcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22xcivic &raquo;</TD></TR><TR><TD CLASS="quote">....those guys are jerks and haters!!!!!!!!!!!!!!!!!!</TD></TR></TABLE>
go to gdd, theres plenty of those or post a "which swap" "what should i do next" or "swap or turbo"
Old Oct 6, 2005 | 12:58 AM
GeaRb0x's Avatar
bump
Old Oct 6, 2005 | 01:05 AM
crashN2u's Avatar
Default Re: (GeaRb0x)
blow dryer and bug/tar remover is how I did it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kyles ej1 &raquo;</TD></TR><TR><TD CLASS="quote">go to gdd, theres plenty of those or post a "which swap" "what should i do next" or "swap or turbo" </TD></TR></TABLE>
Not anymore...we're the newer, nicer, GDD now. Come by, check us out, bring your flamesuit.
Old Oct 6, 2005 | 01:53 AM
.Steve's Avatar
Default Re: (crashN2u)
Lolol. :D
Old Oct 6, 2005 | 02:11 AM
gapergurlie_18's Avatar
brake cleaner.
Old Oct 6, 2005 | 06:26 AM
C2daIzZle's Avatar
GOOF OFF, & Credit card.
Old Oct 6, 2005 | 06:29 AM
96 EX's Avatar
Default Re: (C2daIzZle)
when i had a ugly sticker on the front on my winshield i used a razor( very very carfully and dont try it with your paint) and then used wd40 to get the glue off. Amazingly it worked like a champ.
