A question about ECU's and such.
So im swapping in a 95 LS...the swap calls for a 90-93 ecu, dist, alter,and injectors. So the 90-93 integ, had 130 hp and 118 tq (im pretty sure) Wouldnt the fuel mapping be different than the 95 LS? will I see a loss in potential by using the injectors and ECU? What caused the difference in hp from the 2 models? compression? cams? Just wondering...Thanks in advance.
-Jake
-Jake
You will actually need the distributor, ecu and injectors from a 90 or 91 LS. 92 was the first year of OBD1. YOur other option would be to convert to OBD1 and use all of the above from your 95.
