Dynoed My B18B1 (low compression built for boost)
Old Oct 5, 2005 | 01:05 PM
FERIOkid's Avatar
Default Dynoed My B18B1 (low compression built for boost)
The motor consists of:
USDM B18B1
-eagle forged H-beam rods
-je forged pistons (9:1CR)
-ACL main and rod bearings
-ARP Rod Bolts and Head Studs
-Balanced rotating assembly
-Exedy stage 2 pressure plate with 3 puck sprung clutch
-Apexi World Sport II
-Exhaust and intake ports all gasket matched
-All new Gaskets and seals
-AEM Short ram intake
-AEM Fuel Pressure Regulator
-B&M Fuel Pressure Guage
-Dual core radiator
-Wire tuck
-Engine bay painted flat black
not to bad i didn't think, can anybody else re-assure me on this one?
fuel pressure was set at 38psi and the timing was set to stock.
Old Oct 5, 2005 | 01:21 PM
FERIOkid's Avatar
Default Re: Dynoed My B18B1 (FERIOkid)
no input eh...
Old Oct 5, 2005 | 01:24 PM
RedEK9's Avatar
bump for input!
Old Oct 5, 2005 | 01:27 PM
FERIOkid's Avatar
Default Re: Dynoed My B18B1 (RedEK9)
just looking for something to compare to really, thanks for the bump man this thread moves real fast
Old Oct 5, 2005 | 03:20 PM
FERIOkid's Avatar
nothing!
Old Oct 5, 2005 | 03:30 PM
pdiggitydogg's Avatar
damn, so thats what mine's gonna be like preboost huh...
Old Oct 5, 2005 | 03:31 PM
monsterb18b's Avatar
Just wondering but, don't you think the horse power is a little low.
I have the same motor with just an AEM Cold air intake and dc 4-2-1 headers. I've never ran a dyno on the car but it doesn't feel like I have that low of HP.
I can take an IS300 of the line and no problem.
I though stock was 142hp. dont know abot whp though.
Old Oct 5, 2005 | 03:37 PM
PRcivicHB's Avatar
Default Re: Dynoed My B18B1 (monsterb18b)
yea but u probably lose about 15% through the drivetrain... so 125whp sounds about right... its the "torque" that makes you fast off the line...
Old Oct 5, 2005 | 03:38 PM
SkoundrelUSA's Avatar
cute little bastard
I'm no expert but that sounds about right to me.
At least its not: https://honda-tech.com/zerothread?id=1387090
Old Oct 5, 2005 | 03:39 PM
Luserkid's Avatar
What is the stock Compression ratio of an LS? 9.8:1? If so then thats right. You loose about 4% or so for each 1 compression you drop. Theres a bigger calculation to this but 4% is the rule of thumb. So it looks like you lost 2% or so from normal. That also looks like one healthy motor.
Old Oct 5, 2005 | 04:21 PM
FERIOkid's Avatar
Default Re: Dynoed My B18B1 (Luserkid)
^^^ thanks man but it was 9.2stock i beleive, not positive (it's the USDM motor). The motor definatly feels healthy, it makes some weird noise when in high RPM but i think it's my DIY gasket match job . I am looking for a ls head right now actually to start building it and a new IM. Prolly blox or the jdmshit one
Old Oct 6, 2005 | 03:47 PM
Cain Marko's Avatar
Rotary Lift Specialist
The stock compression of an LS is 9.2:1, they say the JDM one is slightly higher but bumping up the compression to 9.4:1 wont make a ***** worth of difference.
The reason the motor made the power it did was because of the mods already done to the car, and the fact that the motor has probably a little over 5k miles on it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monsterb18b &raquo;</TD></TR><TR><TD CLASS="quote">Just wondering but, don't you think the horse power is a little low.
I though stock was 142hp. dont know abot whp though.</TD></TR></TABLE>
It may not feel like it, but you probably do have that low of HP. LS motors arent HP monsters, thats what boost on these motors is for.
Old Oct 6, 2005 | 04:05 PM
khmboostedeh2's Avatar
Default Re: Dynoed My B18B1 (.Rusty)
hey jon, did you snap any pics at the dyno?
ive got a couple of your car if you want them
Old Oct 6, 2005 | 04:39 PM
Cain Marko's Avatar
Default Re: Dynoed My B18B1 (Jeterkm02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jeterkm02 &raquo;</TD></TR><TR><TD CLASS="quote">hey jon, did you snap any pics at the dyno?
ive got a couple of your car if you want them</TD></TR></TABLE>
This is jon we're talkin about, does he go anywhere without his camera?
I believe he has some on his computer, I think I saw one of your car, but I am not sure.
Old Oct 6, 2005 | 04:54 PM
FalkenSiR's Avatar
ok numbers for a b18b. I've seen stock (i/h/e) b18b's make 120 whp. You are making 7 more. Torque is avg for an LS motor too. Numbers are going to change dramatically under boost, not hating here. Just stating what I know/seen.
Old Oct 6, 2005 | 04:59 PM
FERIOkid's Avatar
Default Re: Dynoed My B18B1 (fast88std)
^^ thanks a lot man , I was happy with the results for the most part
Old Oct 6, 2005 | 05:25 PM
Anthony's Avatar
Mr. Fuch-yu
Rule of Thumb:
14.7 psi = 1.0 bar atmosperic pressure. This is what your b18b is under now and it is making 127 whp. That being said suppose you boost it to 14.7 psi, that would double the normal pressure that your normally aspirated motor is under, rendering double the horsepower. Look for roughly 254whp at 14.7psi. Nothing to scoff at. There's my 2 cents.
-Red
Old Oct 6, 2005 | 05:28 PM
Cain Marko's Avatar
Default Re: Dynoed My B18B1 (nitrared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nitrared &raquo;</TD></TR><TR><TD CLASS="quote">Rule of Thumb:
-Red</TD></TR></TABLE>
Wouldn't this vary depending on turbo size and trim? Not trying to be a dick, just curious.
VTC_CiViC's Avatar
I don't know if it's just the air down here, but a basically modded LS (I/H/E) will usually see around 125-130whp +/-, 112 seems a good bit low IMO.
Old Oct 6, 2005 | 05:31 PM
Cain Marko's Avatar
Default Re: Dynoed My B18B1 (VTC_CiViC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTC_CiViC &raquo;</TD></TR><TR><TD CLASS="quote">I don't know if it's just the air down here, but a basically modded LS (I/H/E) will usually see around 125-130whp +/-, 112 seems a good bit low IMO.</TD></TR></TABLE>
112 is the torque he made
Old Oct 6, 2005 | 05:51 PM
FERIOkid's Avatar
my friend just made 235whp on a gsr with 6psi with a 2inch dp and 2 1/4 exaust so i'm thinking that Ill be seeing better number than 245 with a fullrace kid
I've seen stock b16's at 10psi made 320whp with the stage 1 fullrace kit, the non GT kit
what i'm going for: http://www.full-race.com/catal...d=195
oh ya and follow your signature
Old Oct 6, 2005 | 06:25 PM
dunkd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FERIOkid &raquo;</TD></TR><TR><TD CLASS="quote">no input eh...</TD></TR></TABLE>
HOLY **** MAN!! THATS SICK!! WOWWWZERS
Old Oct 6, 2005 | 06:27 PM
Anthony's Avatar
Mr. Fuch-yu
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Rusty &raquo;</TD></TR><TR><TD CLASS="quote">
Wouldn't this vary depending on turbo size and trim? Not trying to be a dick, just curious.</TD></TR></TABLE>
Yeah it varies a little. It is good to use as a rule of thumb though.
Old Oct 6, 2005 | 06:41 PM
Cain Marko's Avatar
Default Re: Dynoed My B18B1 (dunkd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd &raquo;</TD></TR><TR><TD CLASS="quote">
HOLY **** MAN!! THATS SICK!! WOWWWZERS</TD></TR></TABLE>
Eat poopay!
Now would be a good time to post up your race gas dyno sheet(the one with vtak )
Old Oct 6, 2005 | 06:42 PM
FERIOkid's Avatar
^^^^ what i thought
