Squeaking sound when accerlating
i got a 94 integra ls and everytime i acclerate theres a squeak noise. this also happens when i go over bumps and stuff. anyone have an idea on whats wrong? iam not sure if it's the suspension because i just put on new shocks and springs yesterday (agx/eibach). and for some reason the abs unit sounds like its trying to pump fluid but nothings going... i refill the fluid often and it makes a humming noise. any advice would be nice
thanks
.thanks
Take it easy there punchy. Noone will with the attitude.
Are you sure it's not a belt squeek that you're hearing? If it is in the suspension, do you have a camber kit with poly bushings? That squeeks sometimes.
As for the ABS, it needs to be bled. After the bleed procedure if it still pumps intermittently while the engine is running, you may have a leak somewhere.
Patience is a virtue.
iam sorry i didn't mean it in that way. i just need some help... as for the tech question, i still using using the stock bushings. and for the abs it's been bled but could it be the unit itself?
mine squeaks, most noticeably when I turn. But I think it does it all the time... I researched it awhile back and it seemed to be the bushings... I'm just too lazy to replace them.
blackriceman
Jun 13, 2004 09:04 AM
