OBD2--->OBD1 questions
Old Oct 5, 2005 | 10:00 AM
Azn Kenny's Avatar
Default OBD2--->OBD1 questions
I threw a CEL due to my test pipe and my friend told me about this conversion and all I'd need was the OBD1 ecu and a jumper harness.
So what exactly will this do? Can I expect and gains or is it just to get rid of the CEL.
Also, anything else I'd need?
Thanks.
Old Oct 5, 2005 | 10:01 AM
Azn Kenny's Avatar
Default Re: OBD2--->OBD1 questions (kennyfsu)
Also, any one have to sell?
Old Oct 5, 2005 | 11:08 AM
SOHCVTECx2's Avatar
I had the same problem... but like you said get a OBD1 JDM ecu and a OBD 1 jumper harness. The OBD1 ecu runs off of just 1 O2 sensor on the pipe while the OBD2 runs off 2 O2 sensors. Thats why you are throwing a CEL. Plus with OBD1 ecus depending wat car you have, but with my GSR i can rev up to 8500 instead of 8k once i converted over.
Old Oct 5, 2005 | 11:17 AM
iH8RICERZ's Avatar
Default Re: (SOHCVTECx2)
as mentioned above...only down side to jdm ecu's is that there's a speed govenor which will not let you rev past 120ish? Depending on what year your integra is, that will determine what version harness you need. 96-99 integras use obd2A-1 conversion harness, and 00-01 integras use obd2B-1 conversion harness. Basically its plug and play. Also, when you convert to obd1, you have many more options when it comes to tuning. Hondata/Crome/Uberdata/generic base maps & programs/etc.
Old Oct 5, 2005 | 12:27 PM
Azn Kenny's Avatar
I love this site, thanks fellas!
shorty5198
Honda Civic (2001 - 2005)
Jul 25, 2006 05:25 AM
trust01
Mar 2, 2006 04:18 PM
mainline69
Feb 9, 2005 06:35 AM
1fstevo
Nov 21, 2003 09:44 AM
