5 lugs conversion question *HELP*
ok so i just got some ITR 5lugs conversion from my friend.. he crash his itr and i got the suspension for free.. problem is when he crashed the car he slightly bent the front spindles... is there any way i can slavage the conversion and the use the conversion? can i just swap out the spindles from a civic and put it on the hub?
any info would help me out alot.. i really want to do the converion to my 00 coupe..
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Bent the front spindles? Like the axel? Just go to http://www.acuraoemparts.com and replace what is bent. Your all good.
i dont have the axels that came from his car.. the bents only on one spindle the driver side i believe.. the bend isnt that bad.. its slightly bent like 3cm.. everything else is fine..is there anyway i can swap out just the spindles?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeviousCTR »</TD></TR><TR><TD CLASS="quote">i dont have the axels that came from his car.. the bents only on one spindle the driver side i believe.. the bend isnt that bad.. its slightly bent like 3cm.. everything else is fine..is there anyway i can swap out just the spindles?</TD></TR></TABLE>
well since its bent anyway...why not just try?
if you can find a gsr one you can swap the 5 lug hub over. thats what i plan to do also because i got in an accident and the bitch snaped my spindle right in half. or buy a new one from honda its like 200ish
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hayabusa160 »</TD></TR><TR><TD CLASS="quote">if you can find a gsr one you can swap the 5 lug hub over. thats what i plan to do also because i got in an accident and the bitch snaped my spindle right in half. or buy a new one from honda its like 200ish</TD></TR></TABLE>
so if the gsr spindle fit then spindles from a civic will fit right? say from a 99-00 em1?
long as the brakes are 10.3 yes
which one do you need? i got a gsr front brake swap so i can swap my hub over but i only need the passenger side so im going to sell my driver side
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hayabusa160 »</TD></TR><TR><TD CLASS="quote">i gess 40+ shipping </TD></TR></TABLE>
where are u located? if local maybe i can pick up
dc2 frm da island
Sep 10, 2007 08:15 AM
hj
Oct 2, 2003 06:03 PM
