The low fuel light in ef's is real helpful..
Yeah right!!
Mine came on 2 seconds after the engine started boggin down.
I shut it off before it completely died.
I figured I had enough gas to make it to the next exit since the low fuel light hadnt came on.
I had wondered why I never saw the low fuel light before.
Now I know why!
Left me on the side of the I-71 freeway at 4am in the freezing cold just when it was starting to snow.
Now I know why!
I put gas in the car before I left cinci!
I was planning on pulling over at the next exit where there is a Chevron..
I thought I had enough time since the fuel light didnt even come on..
I didn't think it had one ..... I was used to the little gas dealy coming on in the R to let me know I had about 50 miles left.
Guess I'm glad I've never seen one in my Civic .....
I did put in some gas when I left.
I was doing 80-115mph the whole way down 71 so it ate right threw a half of a tank..
Hatchbacks have fuel lights? I've had one since 1994 and never noticed a low fuel light, and I've run that thing pretty low. Maybe it's burnt out like my check engine light?!?
Its in a spot where you cant tell until it lights up.
its not like the seatbelt light where you can see it when its not lit up..
i dunno it was only on for a second and i had bigger concerns at the time.
[Modified by 91ED7Si, 2:27 PM 3/4/2002]
a sure fire way other than the light to find out your running low on gas is if on turns your car starts sputtering and trying to turn off, sadly this has been my warning a couple times.
I had two passengers and it was pretty cold and real windy..
Plus the rpms were really high at that speed..
Most of the time was at or near full throttle..
I was getting 20MPG[120miles devided by 6gallons]
Yall are making me think im ****** trippin!
**** it might have been another light but I dont see why it would come on at that exact time...
fuel light? wtf! probably your cel. no fuel light in a usdm cluster. only jdm and then you gotta wire it up to the sensor in the tank to make it work.
THEY DONT HAVE A LOW FUEL LIGHT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!
drrep
Jun 1, 2004 03:11 AM
