how do i tune h22 with stage 4 dataloging?
Old Oct 4, 2005 | 08:08 PM
accordparts96's Avatar
Default how do i tune h22 with stage 4 dataloging?
This is my set up and what all i got... i just need to know how to tune it and what a/f ratio i should do..
Skunk2 cam gears
Skunk2 intake manifold pro2 series the new one
Skunk2 68 mm throttle body
Dc headers
Full custom exhaust greedy
P16 chipped computer
v-afc
str fuel rail
fuel regulator
I relocated iat sensor
I blocked off egr valve
Tein 1400.00 coilovers ss
Urethane engine mounts and bushings
Threwout the whole car
Throttle cable
Greedy stage 1 clutch
Stupid ACCORD TRANNY(I know junk geared to long)
Hks ground block with 7 ground cables
Hks voltage stabilizer
After market radiator cap.
Only have altinator
Oil catch tank
Msd 6al ignition
Msd blaster coil
Denso iridium plugs
10.5 mm wires
Aem fuel filter
Wrapped headers and intake
Obx radiator hoses
Eliminated abs and whole heater system threwout the whole car
Zex 55. shot haven’t used yet. Also have methonal injection not used yet
Obx oil pan
And a lot of extras for suspension ..
Obx throttle body spacer
Synthetic oil and clutch fluid
just bought the following
aem wideband uego controller 6 in 1 gauge
A laptop and a palm zire 21
Socketed P28 ECU
Hondata stage 4 with:
Quick rundown of the Hondata features:
Tunable fuel and ignition maps – extract to most power and best drivability out of your engine
Adjustable rev limiter – raise the rev limiter if it kicks in too early for your new powerband (cams, head work, etc..)
Datalogging – monitor engine sensors and condition real-time. Can also be played back for analysis
Shift light – uses your check engine light for a shift light without any modification (can be turned off), or simply use a bulb or LED
VTEC control – raise or lower VTEC crossover within 1RPM. The software can automatically compensate for fuel/ignition maps
Launch control – build boost or achieve a more repeatable launch with a temporary rev limiter that’s only active when launching
Full throttle shift – shift without having to lift off the throttle, retains boost.
Boost – system supports tuning for boost and includes expanded fuel/ignition maps
A/C cutout – turns off the A/C system at specified throttle input and/or engine speed
EEPROM burner – hardware and software to burn your own fuel/ignition maps when tuning
EEPROM chip
Speed limiter removal – if applicable, mainly on JDM ECU’s
Rom Editor – licensed software from Hondata
HondaLogger – software used for datalogging (can also datalog from Palm devices using PalmLog)
Change most settings from the cockpit using the infamous red button.
All hardware needed for the 3-step – switches, wires, etc..
Please help i was told with all this i can tune my car by my self but have no clue were to start.
WavyIntegra
Jan 11, 2010 12:08 PM
bigz187
Mar 19, 2006 06:28 PM
juicedh22
Apr 19, 2005 08:43 PM
juicedh22
Apr 14, 2005 11:53 PM
95singlecamvtec
Mar 31, 2005 09:12 PM
