Removing alternator pulley
Nope, can't do it that way, you will probably have to remove the alternator all the way. The nut is 22mm, and since I didn't have access to air tools, I had to buy a 22mm box-end wrench (the kind w/ the offset head) to fit down in the pulley, and hold the shaft w/ a 10mm socket. But either way, the nut is 22mm.
It is also threaded normal, lefty loosey righty tighty
[Modified by PatrickGSR94, 9:00 AM 3/4/2002]
I don't think its reverse thread. I need to take my pulley off to install the AEM pulley. I loosened the alternator and pointed it down then used my impact gun to take off the pulley.
So... regular thread... 14mm nut.
I'm just telling you my experience. I could care less how you spend your money. My steering stiffened a little. That's all I was really expecting. I didn't see any power gain at all.
Ritchie
May 17, 2007 11:10 AM
TrueZen
May 2, 2005 03:20 PM
elpermgrande
10
Jan 14, 2003 11:48 AM
