1996 cig. lighter fuse location
If I remember right, it should be under the hood fuse box. Check for blown fuse. Sorry if I tell you wrong. I do not own an accord anymore, but used to.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sony224422 »</TD></TR><TR><TD CLASS="quote">Where is it? I think i blew it but i can't locate a fuse thats blown on the normal inside box by the brake pedal.</TD></TR></TABLE>
u got to chk 2 fuses .1 in the underdash fuse box,, fuse # 11 10 amps, the other in the underhood fuse box, fuse # 36 15 amp.....if either is blown, it will not give power to the cigarette liter relay thus u will get no power at cigarette liter.......if fuses are ok,, chk for power at white/blue wire going into cig liter, if no power most likely a bad relay,,,,,,if u got power chk the black wire for ground at cig liter ..if no ground, u got bad wiring, if u got good ground u have a bad cigar liter assembly
si0385.
20
Apr 17, 2006 08:12 AM
racecarpete
Audio / Security / Video
Mar 30, 2003 07:44 PM
