plate for the climate control on ek dashboard...
Old Oct 4, 2005 | 01:51 PM
VWVORTEX's Avatar
Default plate for the climate control on ek dashboard...
well, i removed my dashboard, and removed the cover, now.. i tried making a fiberglass plate, and it came out crappy, anyone mind helping, i basicly just need a plate that looks clean to cover the hole.. i need to mount a 5" lcd, and some toggles, nothing major there. any idears ?
some thin sheet metal, x brace it on the back ?.. use tin sheers to cut it ?
Old Oct 5, 2005 | 04:09 AM
VWVORTEX's Avatar
Default Re: plate for the climate control on ek dashboard... (GripStar)
Old Oct 5, 2005 | 05:45 AM
mike1114's Avatar
many places sell carbon fiber plates you can cut to size
Old Oct 5, 2005 | 06:51 AM
DaveF's Avatar
Default Re: plate for the climate control on ek dashboard... (mike1114)
i had that done to my car, and i think it sucks. i put the stock **** back in. ill find pics.
Old Oct 5, 2005 | 08:31 AM
jolt-tsp's Avatar
Default Re: plate for the climate control on ek dashboard... (Dturbocivic)
Thats exactly how my car is right now. I'm not too fond of it, but it works. I used tin sheers to cut and a dremel to smooth the edges. It looks pretty bad, but my whole car looks bad, so I'm not too concerned with it.
Old Oct 5, 2005 | 01:06 PM
2old_honda's Avatar
the best way to get a nice cut on that type of thing would be to use a band-saw
Old Oct 5, 2005 | 03:16 PM
Chronicsinners's Avatar
Default Re: plate for the climate control on ek dashboard... (2old_honda)
i can laser cut plastic into dash panel with a good template. My computers in the shop so i cant show you pictures of my work, but drop me a pm or a design and i can give you a quote
Old Oct 5, 2005 | 08:03 PM
bigTom's Avatar
Default Re: plate for the climate control on ek dashboard... (Chronicsinners)
this is the only pic i have of a 96 climate control... i cant find any of the 99-00 ones... not to mention i like that center piece much better... i always use the abs plastic sheets that audio places ussually have
Old Oct 5, 2005 | 08:58 PM
tony1's Avatar
Default Re: plate for the climate control on ek dashboard... (bigTom)
Doesn't it get hot in the car with the turbo right there? You should put a heat shield around it or something, it would probably help the spool too. Turbos like heat you know...
Old Oct 5, 2005 | 09:10 PM
97turbols's Avatar
Default Re: plate for the climate control on ek dashboard... (tony1)
remote mount Biotch!!
Old Oct 6, 2005 | 02:01 PM
m R g S r's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Doesn't it get hot in the car with the turbo right there? You should put a heat shield around it or something, it would probably help the spool too. Turbos like heat you know...</TD></TR></TABLE>
i was like wtf?
then i saw the pic lol
csubucky19
Jun 12, 2008 05:54 PM
BIGthings
Mar 1, 2007 01:09 AM
Setsuna F Seiei
10
Jul 5, 2005 05:10 AM
