Wheels, Tires, Brakes, and Suspension Wheel, Tire, Brake and Suspension Parts (Wheels, Tires, Coilovers, Lug Nuts, Camber Kits, Rim/Tire Tools)
Rotora Big Brake Kits - 4 Piston calipers!
Old Oct 4, 2005 | 01:28 PM
prostreetonline's Avatar
Default Rotora Big Brake Kits - 4 Piston calipers!
We also have one set that was mounted on a car, but never driven on. $1000 SHIPPED. it has red calipers.
Catered for the performance enthusiasts, Rotora introduces its premier big brake upgrade. Fully cast and CNC machined to ensure the highest quality; Rotoras 4 piston caliper brake kit system improves the pedal feel by increasing the clamping force while utilizing the stock master cylinder to ensure stock brake balance. Using this kit, end users receive a race-proven setup performance solution combined with an appealing aesthetic application.
Contents of Rotora Brake Kit
TWO 1 piece cross-drilled and slotted vented e-coated black rotors ( 330mm or 295mm, depending on applicaiton )
TWO 2-piece cast aluminum 4-piston calipers ( red or blue caliper of your choice )
TWO anodized black caliper mounting brackets
Rotora street performance pads
Stainless Steel braided brake lines ( DOT Approved)
All systems are ABS compatible, and direct bolt on replacement to all stock front suspension systems, with 15-25 percent larger surface area compared to stock.
Applications and prices here: http://www.prostreetonline.com..._kits/
Modified by prostreetonline at 11:55 AM 10/18/2005
Old Oct 7, 2005 | 06:02 AM
godnf8's Avatar
Default Re: Rotora Big Brake Kits - 4 Piston calipers! (prostreetonline)
Will either of the kits work with 16" wheels.
Old Oct 7, 2005 | 07:57 AM
Default Re: (vrooom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vrooom &raquo;</TD></TR><TR><TD CLASS="quote">No special pricing for H-T ??? BOOOOOOo </TD></TR></TABLE>
You kidding me? of course we do! Use coupon code HT5D for 5% off
Old Oct 7, 2005 | 08:00 AM
Default Re: Rotora Big Brake Kits - 4 Piston calipers! (godnf8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by godnf8 &raquo;</TD></TR><TR><TD CLASS="quote">Will either of the kits work with 16" wheels.</TD></TR></TABLE>
Maybe, depending on the wheel, but I doubt it. Give rotora a call, they have all wheel fitment charts with their kits: 1-888-990-0899
Old Oct 8, 2005 | 06:42 PM
bump!
Old Oct 12, 2005 | 03:23 PM
Old Oct 15, 2005 | 03:42 PM
Thanks for the orders!
Old Oct 18, 2005 | 10:54 AM
bump!
Old Oct 23, 2005 | 10:07 AM
intxactdgsr
Oct 19, 2005 02:03 PM
prostreetonline
13
Apr 1, 2004 09:20 PM
blueturboteg
Dec 3, 2003 03:27 PM
