what wire on ecu for o2 sensor gauge delsol
Old Oct 4, 2005 | 11:10 AM
spoonzdelsol's Avatar
Default what wire on ecu for air fuel gauge delsol p28
I am hooking up my aftermarket air fuel gauge and i am wondering which wire on the ecu do i hook it up to it is a 93 del sol with a p28 ecu 5 speed
Old Oct 4, 2005 | 11:23 AM
any help would be nice like pin out ,color of wire.
Old Oct 4, 2005 | 12:06 PM
all i need to know is which wire on the ecu i hook my gauge wire to there are to o2 wires on the pin out which one do i hook it to
Old Oct 4, 2005 | 12:13 PM
civic_driver's Avatar
o2 signal... i think it's the white wire on the o2 sensor..don't quote me on this though... could be the green one... you can easily test it with a multimeter... the heater power wire has constant voltage while the signal changes based on A/F ratio..should be easy to figure it out..
search for the ECU diagrams that are floating all over the place here.. you should be able to figure it out
Old Oct 4, 2005 | 12:16 PM
Based on this:
http://www.hondaswap.com/forum...33248
O2 signal is the white wire, green is signal ground and the 2 black wires are heater power and ground
you want the o2 signal (white) wire..
good luck!
Old Oct 4, 2005 | 12:19 PM
yeah but which one on the ecu plug is the right wire i use? thats what i am wondering about thanks for the info anyways
Old Oct 4, 2005 | 12:29 PM
well you can run it straight from the o2 through the firewall to your gauge...
or if you want a cleaner install, search here for ecu diagrams to find the correct ecu pin
Old Oct 4, 2005 | 12:33 PM
yeah thats what i am wanting is to the ecu but there are 2 diffrent wires on the ecu thats my problem
Old Oct 4, 2005 | 12:37 PM
D14 is your o2 signal
http://www.plxdevices.com/ecudatabase.htm
Old Oct 4, 2005 | 12:40 PM
only one problem thats a p30 i have a p28 ecu
Aaron M
Jun 7, 2005 06:24 PM
vtecb20coupe
Oct 6, 2004 05:02 PM
JDMegCivic86
Oct 3, 2004 06:01 PM
Hybrid CRX
Jan 7, 2004 03:39 PM
1tyme
Nov 12, 2002 05:10 PM
