K20A/K20A2 Swap in 1997 Hatchback
Old Oct 4, 2005 | 06:17 AM
Hatch_Back_97's Avatar
Default K20A/K20A2 Swap in 1997 Hatchback
Ok guys, its official, I am saving up for the K series swap, forget all the overdone B series and H series out there, I want and need to be different, especially for future shows. I need a list like I've seen for old Civics of everything that I'll need to make it a turn key project. I'll be installing it myself with friends help of course and other than that all I gotta worry about is what prices, etc. everythign will run. This will be going into my 1997 Civic hatchback.
Old Oct 4, 2005 | 07:12 AM
Frozen E's Avatar
H-T White Ops
Wanna be different? Drop a 427 smallblock into your hatch. THAT'D be different.
Old Oct 4, 2005 | 07:26 AM
SkoundrelUSA's Avatar
cute little bastard
Default Re: K20A/K20A2 Swap in 1997 Hatchback (Hatch_Back_97)
Go buy this month or last months issue of HondaTuning (95 Prelude on the cover). They do a K swap into an EK
Old Oct 4, 2005 | 07:35 AM
JDM-EJ1's Avatar
Default Re: K20A/K20A2 Swap in 1997 Hatchback (SkoundrelUSA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA &raquo;</TD></TR><TR><TD CLASS="quote">Go buy this month or last months issue of HondaTuning (95 Prelude on the cover). They do a K swap into an EK</TD></TR></TABLE>
Yeah, and they do a really good job of how to do it too.
Old Nov 1, 2005 | 03:41 PM
Lttran's Avatar
Old Nov 1, 2005 | 03:45 PM
vancoland's Avatar
pm litterbox...im sure he can point you in the right direction
Old Nov 1, 2005 | 03:51 PM
aspec101's Avatar
visit k20a.org tons of info on this project. There are alot of ways to cut costs w/o cutting corners. Some of the ways I have found are:
Modify existing k fuel rail buy welding a -6 an fitting on to run to a fpr. save 100
use type s axles with b series outters, or straight base rsx axles or ep3 axles save 200
use prc ecu instead of kpro if you are running n/a save 800
used tsx stock header instead of aftermarket save 300-1000
those are some ways to cut almost 1500-2000 off of the swap.
things you can't bypass
swap harness - you can make your own but lots of time to research and source stuff
swap mounts
hope this helps.
jdmgev
24
Aug 6, 2014 08:30 PM
ef9_frosty
Dec 5, 2007 09:09 AM
808EK4
Oct 6, 2006 11:34 AM
Team PHATBOYZ
Oct 17, 2005 12:04 AM
